Convert Sirius to XM
Old Apr 24, 2006 | 10:22 AM
wazZ's Avatar
wazZ
Default Convert Sirius to XM
I have a 2005 Touring with the Bose system, no navigation. There are three buttons; radio, tape & CD. It currently is set up to access the satellite radio by pressing the radio button until Sat is visible. I want to change to XM radio. Is it possible and what do I need?
Old Apr 24, 2006 | 02:13 PM
jpm_fan's Avatar
jpm_fan
First, why would you want to do that? SIRIUS kicks XM's ***.
Anyway, there's a box that sends the SIRIUS signal to the HU. You need to swap that out with the XM box if you want built in sat. To the best of my knowledge, only a Nissan dealer sells the box for Nissans. You can try crutchfield.com to be sure.
Old Apr 24, 2006 | 02:39 PM
wazZ's Avatar
wazZ
Default convert
Does the Z have just a sirius box or is there also an adapter? The XM direct boxes are easy to come by, it's the adapter for the Bose radio that poses the problem. If the Sirius box plugs in direct then maybe the XM box does as well.
Old Apr 25, 2006 | 03:07 PM
NYC_G35C's Avatar
NYC_G35C
EverythingG35.com Store | OEM XM Module
in the trunk of your Z on the left side under the floorboards is the OEM amplifier as well as the OEM Sirius satellite reciever. you need to remove the Sirius reciever and antenna, and install the new XM reciever and antenna. then you should be able to access the XM just like you do the Sirius now.
Old Apr 26, 2006 | 02:32 PM
wazZ's Avatar
wazZ
Default Not quite
I found the Sirius receiver attached to the rear of the vehicle, near the floor on the passenger side. You can actually get at it by removing the spare tire. The Sirius box is made by clarion and is a Model EN186E. The connections are nothing like the XM direct. It has a large modular plug that apparently goes to the radio and a small modular plug for the antenna and one for the Terk adapter. It doesn't seem possible.
Old Apr 26, 2006 | 05:28 PM
NYC_G35C's Avatar
NYC_G35C
yes, you have to use the Nissan XM Reciever, which has the same larger modular plug that your current Sirius one does. the XM Direct has a different connection. check out the link i posted above.... the Nissan reciever is the only one that will plug into the factory system and allow you to control it from your stock headunit
norrix420
350Z Roadster
May 23, 2022 05:11 PM
sales@czp
Sep 23, 2019 03:30 PM
ejv8s10
350Z Roadster
33
Jun 14, 2016 08:31 PM
Fixxxercask
Interior
Oct 6, 2015 10:17 AM
