Factory Sub enclosure
Old Apr 26, 2006 | 03:38 PM
TomeiZ33's Avatar
TomeiZ33
Vendor - Former Vendor
Default Factory Sub enclosure
I Was wondering if the factory sub encolsure behind the driver seat is a sealed enclosure. I wanted to put a 10 inch salo baric in there and they require sealed enclosures. Anyone have any experience with throwing in aftermarket subs in the OEM slot? Any help would be ko0l thanks.
Old Apr 26, 2006 | 06:07 PM
Swiffer's Avatar
Swiffer
Its not sealed. You can place an aftermarket sub in the hole, but I would place some dynomat in the cubby to help prevent rattles, and help seal it a little better. To get better sound, you can go with a free-air sub. For even better results, you can build a custom enclosure that fits in that compartment.
Old Apr 27, 2006 | 01:57 AM
abyss's Avatar
abyss
its not even deep enough for a solo baric is it?
Old Apr 27, 2006 | 03:45 AM
Swiffer's Avatar
Swiffer
It is pretty deep. If you have the specs for that sub, you can take the panel off and measure how much room is there.
Old Apr 27, 2006 | 04:09 AM
TomeiZ33's Avatar
TomeiZ33
Yeah the space behind your seat is enough to a hold a 12" sub if wanted. Im just wondering how i would be able to retro fit a salo baric into it for better bumps....the dyno matting idea doesn't sound bad. It would be kinda hard to make a enclosure inside that area seeing as though it is so0 hard to even get your hand in there to work on anything. Cutting of the metal might be a idea but im trying to stay away from that at this point. Yo Camaro194 wut would you do if you had a salo baric. Best economical way that is ( without purchasing a new sub and getting a custom enclosure made)
Old Apr 27, 2006 | 06:39 AM
abyss's Avatar
abyss
Is it a Solo Baric-X or an L5-7?
Your gonna have to either build a custom enclosure for that area or another part of the car because solo barics need a deep, leak free box or they sound like ****.
-I'd use Hushmat instead of dynomat, alot better material and stick better..as well as cheaper.
-Get a board and cut a mount for your sub, then seal it. I haven't yet had the opportunity o put a system in the Z so I don't know exactly how deep the compartment is. If your running a Solo-X your not gonna want it in there though unless you do have a real enclosure built.
Old Apr 27, 2006 | 08:02 AM
Swiffer's Avatar
Swiffer
Here are the dimensions of a box that will fit in there. I'm not sure what a solo baric requires, but this will give you an idea:
Old Apr 30, 2006 | 07:56 AM
BadBlood's Avatar
BadBlood
[QUOTE=camaro194]Here are the dimensions of a box that will fit in there. I'm not sure what a solo baric requires, but this will give you an idea:
Hey, thanks for the diagram, I've been looking to start making a box like this.. I haven't looked back there -too- much, so forgive the stupid question, but is this diagram showing a front-facing box, or an upward facing box?
Are you using a box like this?
Thanks!
Old Apr 30, 2006 | 11:17 AM
Swiffer's Avatar
Swiffer
Thanks!
The box is upside down in the diagram. The sub will be firing down. I have yet to build this box, but there have been others who have.
Old Apr 30, 2006 | 11:53 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Mind your Thiel-Small parameters - that's not a very big box.
Old May 1, 2006 | 07:07 PM
BadBlood's Avatar
BadBlood
I'm not a speaker genius, so please excuse the dumb question, but it seems that most 10" subs want around .75 cu ft. (around 700 cu in.) wouldn't this box be about right , or mabye even large by the time the volume of the sub itself is displaced?
Again sorry if this is dumb, I'm just very interested in building a stealth box like this one.
The Sub I'm planning on is the Infinity 1042w Reference DVC (91 DB, Vas = 1.4, rec. sealed size = .75)
Old May 2, 2006 | 11:41 AM
pln2311's Avatar
pln2311
How would that sound being fired down?
Old May 2, 2006 | 12:35 PM
cer2225's Avatar
cer2225
Bass is an onmidirectional sound so the direction the sub is facing is a non issue.
Old May 2, 2006 | 01:56 PM
MRMDFY's Avatar
MRMDFY
.75 cubic feet is 1296 cubic inches, not "around 700".
.75(12 * 12 * 12) = 1296
Old May 2, 2006 | 05:15 PM
BadBlood's Avatar
BadBlood
hehe, Thanks I knew I was missing something stupid (geometry was a long time ago)... I converted to inches before calculating volume...
(12*.75)x (12*.75)x(12*.75) = 729
Big whoops
Old May 3, 2006 | 09:43 AM
Nazar's Avatar
Nazar
You can try one of our new boxes and get in the groub buy if you want.
Old May 3, 2006 | 03:41 PM
ZWildZ's Avatar
ZWildZ
How much for the box pictured? What type of speaker would go in it and what would you recommend to power it?
Old May 3, 2006 | 03:45 PM
Swiffer's Avatar
Swiffer
There is another thread for this topic. Here are the details on the price:
GROUP BUY PRICE WILL BE $250/each + SHIPPING.
ONLY 7 ENCLOSURES WILL BE SOLD AT THIS PRICE...
AFTER THAT THE PRICE WILL BE $299.95/each + Shipping.
sales@czp
Sep 23, 2019 03:30 PM
Depravity
Oct 1, 2015 04:49 PM
