Head unit installed few problems Help
I just bought the Pioneer DEH-P80MP (http://www.cardomain.com/item/PIODEHP80MP) and I have it installed but the radio stations are not coming in clear. Is there an adapter that I can buy because maybe the conector isnt long enough? My second problem is that I have a dell dj hooked up to the output in the back of my unit and I canr get it to play through the AUX option. I have tried all three of the outputs and still cant get it to play. I am using a Y cable that is made for I pods and dell dj's and plugs right into the headphone input on the dell dj. If anyone has any advice that would be great.
Thanks,
Killa
Thanks,
Killa
I bet that you didnt hook up the radio signal booster wire when you wired up your harness. you will need to connect the remote turn on wire from the head unit to the booster wire in the stock harness. Im not sure what color that wire is though...
