In Car PC Building your own!! Links!
Old Mar 30, 2003 | 08:22 PM
  #321
Scafremon's Avatar
Scafremon
Funky mouse
Old Mar 30, 2003 | 08:32 PM
  #322
aggie300zx's Avatar
aggie300zx
Hehe, I was tempted to buy that set at CompUSA awhile back, but wasn't sure how it would work. Glad to hear that it worked out for you.
Good point on the Deluo GPS receiver. For $100 not a bad deal and it says it will work with MS Street & Trips, MS Map Point, Delorme Street Atlas, and TravRoute Door-to-Door 2000 so if I don;t like the software that comes with it (Rand McNally Streetfinder) I could always buy one of the other software packages at a later date.
Will hopefully be ordering the Opus 150W DC-DC power supply tomorrow.
Oh, and just for kicks decided to mess around with a TV Tuner card in the machine. It worked great in the house, but we will see how it does with an antenna in the car. I don't expect a whole lot, but for $40 the tv tuner card will get used elsewhere if it doesn't work in the car.
Old Mar 30, 2003 | 08:46 PM
  #323
abz123's Avatar
abz123
Aggie, there's always add-ons...lol. That's what's great about it.
Old Mar 30, 2003 | 08:55 PM
  #324
ares's Avatar
ares
Veteran
one problem with that mouse... can it tell the difference between you moving it and the car moving? might be tough to use when the car is in motion...
I hope touch screen and voice is enough, I have a USB keyboard and mouse to use when needed, but Im trying my best not to use either on a regular basis, whatever the touchscreen limits me to for typical use is best, I dont need to be fooling with it too much unless Im totally stopped and working on something in particular.
Old Mar 30, 2003 | 09:00 PM
  #325
Scafremon's Avatar
Scafremon
I won't be using any pointing device while the car is in motion.
Old Mar 30, 2003 | 09:16 PM
  #326
ares's Avatar
ares
Veteran
certainly wise, and I was thinking when just driving around with it in the car the cursor will likely be all over, but I suppose not that I think about it that really doesnt make any difference since it shouldnt click itself. let it roam, no big deal.
Old Mar 30, 2003 | 11:24 PM
  #327
alphared's Avatar
alphared
hmmm, this idea just struck me while I was doing my grounding kit.
For all the screws holding the motherboard, hdd, etc... Anybody thought of putting a dap of Loctite on the screws to prevent it from coming loose?
Old Mar 31, 2003 | 05:42 AM
  #328
Scafremon's Avatar
Scafremon
There is a button the bottom that you have to hold in while using the mouse in the air.
Old Mar 31, 2003 | 06:14 AM
  #329
ares's Avatar
ares
Veteran
if it receives rattles that severe, Id be a bit more concerned with other problems involving the electronics.
none the less, my hard drive is held on by nylon screws. and the case is all bolts, hopefully they will stay put. loktite isnt a bad idea, cant hurt anything.
the computer is now "in the car" even if it is hooked up to nothing, and happy to say there are no rattles, and it doesnt seem to mind. still have to do the mailbox slot tho. Im procrastinating on that cause I know thats gonna be a long time goin at it with the ol jigsaw to make the face fit right.
Old Mar 31, 2003 | 06:17 AM
  #330
aggie300zx's Avatar
aggie300zx
jigsaw???? Dude, you need to invest in a good dremel. Trust me, it worked like a champ when I cut a hole in the glove box. Plus, you will want to use a sanding bit with the dremel once you cut the whole to smooth off the plastic edges.
Just don't run it at too high of a speed or you will melt the plastic!
Old Mar 31, 2003 | 08:02 AM
  #331
aggie300zx's Avatar
aggie300zx
So I just ordered the Opus DC-DC 150W power supply, what sux is that they are backordered but should get it sent out in about two weeks.
Learned some interesting things. First this power supply will work with ITX boards, but you need to specify that you are going to use an VIA board (M) when you order because he said they have to a make slight change to the boot up timing for this application.
Also, he told me that the delay in the 90W ITX power supply coming to market was due to some rework that had to be done due to more noise then they wanted. He did mention some additional features that the 90W would have that the current ones don't. One was a heating module add-on that would heat up your system for folks in colder climates...hehe not much of an issue here in Texas. The other feature was something to do with headunit powering on after the PC is powered on....not sure what that would really do for you.
With that being said, I didn't really care for those features so hopefully I will get my Smart power supply in a couple of weeks.
Old Mar 31, 2003 | 08:46 AM
  #332
ares's Avatar
ares
Veteran
oh no no, Im cutting a face plate to mount everything in cleanly out of diamond plate aluminum. I dont think a dremel would take too kindly to that.
I dont fool around.
Old Mar 31, 2003 | 12:07 PM
  #333
all_bark's Avatar
all_bark
I think he means a dremel tool to cut the plastic mailbox slot in the back where the dvd will poke through.
will do a cleaner cut.
(thats how I read it!)
Old Mar 31, 2003 | 12:08 PM
  #334
aggie300zx's Avatar
aggie300zx
Yep, that's what I meant...sorry for the confusion.
Old Apr 5, 2003 | 08:08 AM
  #335
Scafremon's Avatar
Scafremon
aggie300zx:
Did you do the install yourself on your stereo upgrades, specifically the distribution block under the passenger seat?
I'm interested in doing something similiar, and have never done anything like this, so was wondering if you (or others on this forum) can offer guidance.
Old Apr 5, 2003 | 09:10 AM
  #336
aggie300zx's Avatar
aggie300zx
Well, some of it was installed by professionals and some by myself. I've done it all before on several cars, but I learned that some things it's worth paying to have done vs. others.
For example, I installed the headunit, screen, PC, etc. While I let the stereo shop install the amps, speakers.
For the power distribution block, it's not that difficult to do, but it can be tricky sometimes getting through the firewall from the battery. I typically will pay (~$40) a stereo shop to run the power wires for me to my desired location.
Old Apr 6, 2003 | 03:03 PM
  #337
Scafremon's Avatar
Scafremon
PC installed.
Internal Slot-load DVD externally installed.
RF Receiver for keyboard/mouse installed.
GPS Receiver installed.
Need power, screen, audio.
Baby steps....but getting there.
Old Apr 6, 2003 | 03:05 PM
  #338
Scafremon's Avatar
Scafremon
Deluo GPS receiver.
Old Apr 6, 2003 | 03:09 PM
  #339
aggie300zx's Avatar
aggie300zx
Looking good!
I got to use the Deluo GPS on a road trip this weekend. It worked pretty good.
Old Apr 6, 2003 | 07:14 PM
  #340
all_bark's Avatar
all_bark
Originally posted by Scafremon
PC installed.
In this post the picture has the PC and something to the right with 4 red led's and a green one. what is that for?
