Alpine W200 install question
Old May 22, 2006 | 07:12 PM
David2673's Avatar
David2673
Default Alpine W200 install question
Hello there,
I am looking for some input on installing an Alpine W200 unit in my 04 roadster. How easy it it to do yourself? I have never installed a car stereo but it doesn't appear to be too difficult. Any hints on which dash kit to use? Does it have to be modified? I have read in previous posts that the mounting holes need to be redrilled forward a little. Any other hints? Thanks in advance for any tips or input.
David
Old May 22, 2006 | 10:39 PM
jdohman's Avatar
jdohman
If you have never done it Iw ould not start on your 30k roadster and not on a indash monitor.. just my 2 cents though
Old May 23, 2006 | 12:15 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Do you have the bose system?
If so are you going to use the internal head-end amplifiers by-passing the bose ones, or purchase external amplifiers, or connect into the cute little bose amplifiers.
There's an available wiring harness which will solder to the Alpine connector and then plug straight into the stock harness.
Old May 25, 2006 | 11:59 AM
BlueBoxer's Avatar
BlueBoxer
Make sure you install the beauty plate to allow the motorized face to swing open and close with ease. It is a really tight fit.
Old May 25, 2006 | 01:05 PM
minispider's Avatar
minispider
did any one here installed the Alpine Iva-W200 in the nav cubby?...I mean if you don't have nav. and you want to install it there, would it work?....what if you buy the electric cubby from the web, is the cubby plug and play? I have an '06 touring coupe. Any info would be greatly appreciated.
Old May 25, 2006 | 06:06 PM
yellow350rag's Avatar
yellow350rag
i dont really think there's depth behind the nav cubby to install a double din... radios are typically 7-8 inches deep
Old May 26, 2006 | 03:26 AM
minispider's Avatar
minispider
-----oh I see....
Workshop12
Mar 23, 2020 01:45 PM
Suffolk350z
Sep 13, 2015 02:43 PM
Ryan Bonner
350Z Roadster
Sep 8, 2015 04:16 AM
