Remote Car Starter....
Old May 30, 2006 | 09:07 PM
peter2oo2's Avatar
peter2oo2
Default Remote Car Starter....
Hello everyone, I have a quick question, please. What are potential problems with putting a car starter in the Z? Thank You.
Old May 30, 2006 | 09:12 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
your car AT or stick?
with AT: No problem
with Stick: safety issue.
Old May 31, 2006 | 03:00 AM
taurran's Avatar
taurran
If you have a 6MT, Compustar is the only safe way to go.
Old May 31, 2006 | 03:28 AM
gringott's Avatar
gringott
I have seen a couple of posts on here where the ppl with remote start and MT had their cars drive off (without a driver) at the dealership and do some damage.
Old May 31, 2006 | 03:48 AM
thr33f1tty's Avatar
thr33f1tty
^ d@mn that sucks! but doesn't the viper alarm and compustar come with remote start? Soo does that mean your pritty much fuk3d if you get eather on of those and have a mt or can you just have them not install that part of the alarm?
Old May 31, 2006 | 03:50 AM
taurran's Avatar
taurran
Try doing a search for more info. Compustar has a special reserve mode that makes it impossible to start your car while it is in gear or without the parking brake on. Viper does not. That's why they're the only brand that is authorized for remote start installs on manual transmission vehicles.
Old May 31, 2006 | 12:25 PM
hidehide's Avatar
hidehide
Actually.. it is fine as long as you dont put in gear when u park your car..
Just pull the handbrake hard enough. Your car wont roll away even you are not in a gear.
I have remote start in my manual.
But just make sure to tell the person if you let him/her drive ur car..
Old May 31, 2006 | 12:33 PM
HighwaySpeed's Avatar
HighwaySpeed
Lightbulb
Simple...
Have your S.O. go out each day and start your car for you.
Old May 31, 2006 | 01:07 PM
Soccerprep205's Avatar
Soccerprep205
have a diod wired to your brakes so it will do an autokill if a signal is sent to start it while its in gear. thats what my installer did for me. we even tested it so see what would happen if it was in gear. it lurched like an inch or 2... goodluck. i always parked in neutral so when i got this auto start it wasn't a big deal...
Old May 31, 2006 | 01:43 PM
Kolia's Avatar
Kolia
Just get a remote starter for MT equiped cars...
Plenty of options availlable...
Don't be cheap and try to install a 100$ AT system...
Old May 31, 2006 | 01:49 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
lolz, where do you get remote start for $100?
Old May 31, 2006 | 01:56 PM
Kolia's Avatar
Kolia
http://www.canadiantire.ca/assortmen...romSearch=true
www.CanadianTire.com. Use zip code H2E2V1 if you need to search...
Actually, an AT Starter is 69$
A MT starter is 99$.
That's Canadian money, so deduce 10%...
Want the car alarm option added ? 129$
Old May 31, 2006 | 01:59 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
that cheap. I bought my viper alarm with remote start in the mid $300.
Old May 31, 2006 | 05:19 PM
imseksy's Avatar
imseksy
if u install remote start in a MT Z, leave it in gear and start it, wouldnt it just stall out?
Old May 31, 2006 | 05:22 PM
Kolia's Avatar
Kolia
No. Cuz an MT remote starter uses the car's sensors to make sure it's in neutral, the e-brake is on and the hood is closed.
AT starter don't have the e-brake and neutral switches. A MT equiped with that will move with the torque from the starter. The engine might start.
Old May 31, 2006 | 05:32 PM
taurran's Avatar
taurran
Read my above post. Compustar makes remote starter systems that are totally safe for a manual transmission Z. I have one on my car and the included turbo timer functionality works also. You have to have it in "reserve mode" for the timer/starter to work. It has to be out of gear, parking brake engaged, at a stop, and the clutch and brake pedals must be depressed for either feature to work. There is absolutely no way your car can get up and walk away from you. The only downside is that you have to get used to doing all of that if you want to use the feature.
Vipers do not have this feature, and are considered unsafe for this reason. No authorized viper dealer is allowed to install this feature on a MT car. Compustar is the only brand that is authorized to do so.
Old May 31, 2006 | 06:35 PM
pony_killer's Avatar
pony_killer
Arada ninda apa
Do Not Get A Push Start On Your M/t Car!!!!!!!!!!!!!!!! Read My Post "the Worst Day Of My Life" And It Will Tell You Why. =[
Old May 31, 2006 | 08:00 PM
KPierson's Avatar
KPierson
It is possible to somewhat safely install an auto starter on a 6mt if done right.
I personally wouldn't trust the parking brake to keep the car from moving, instead reference the OEM PNP switch signal. The PNP (Park/Neutral Position) switch signal rests at ground when the car is in Neutral, and ONLY when the car is in neutral.
All Viper alarms have dedicated Neutral Safety Switch inputs that can be connected directly to the VQ35s OEM PNP wire.
For reference, the PNP switch is mechanical, which makes it prone to failure. The switch is physically mounted INSIDE the tranny and is similar to the reverse switch that lights up your reverse lights when the tranny is in reverse. I have never heard of any internal tranny switch failures, but it would still be a good idea to test the PNP shutdown once a week.
Old May 31, 2006 | 08:15 PM
jsimms243's Avatar
jsimms243
Alright, Kids. Here is a story for ya.
I had a remote start installed on my last car, 3000GT. It was a manual. The installer made it to where if the car was left in first gear, then it would NOT remote start. Great safety feature, right? It worked great most of the time. Well, long story short, I started the car one day walking out from work. I look up, and my car is taking off across the parking lot. Then I started chasing my car. What a night. Take some advise, put a DOUBLE or TRIPLE safety feature in case one fails somehow.
Old May 31, 2006 | 08:17 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
Originally Posted by jsimms243
started the car one day walking out from work. I look up, and my car is taking off across the parking lot. Then I started chasing my car. What a night. .
hehehe.. ghost rider?
