Rearview Camera OEM style installed!!
Old Sep 12, 2006 | 08:37 PM
gt3's Avatar
gt3
Originally Posted by luke79
I've got the quotation: $284 for the Panasonic camera... holy sh*t...
dgt3, do this cam has rca and can be connected to any rca video input like DVD HU have, or needs something else?
Yeah, I know it's kinda pricey but hopefully these units are built with high quality and will last. It does have a RCA output from a little box so you can easily connect it to any RCA inputs. Since you are in Eurupe (Bonjour!), you may want to look into the Alpine newest reverse camera, which at least AFAIK is available in the UK. It is similar in size, RCA output, and has a wider camera angle.
Alpine Reverse Cam HCE-C100
Old Sep 12, 2006 | 11:42 PM
luke79's Avatar
luke79
thank you mate, you really are my spiritual guide !
I'll take a look to this alpine cam and see if it's affordable
Old Sep 12, 2006 | 11:50 PM
Vick781's Avatar
Vick781
great install gt3
Old Sep 13, 2006 | 07:14 AM
BrickydZ's Avatar
BrickydZ
Default great install... more pics.
Great install.
Can we get a couple of more shots of the bracketing and install under the hatch lip, to see how it attached..
thanks
Old Sep 13, 2006 | 10:51 PM
gt3's Avatar
gt3
Thanks to all for their comments...I will take some photos of the mounting of the camera and post them this weekend!
Old Sep 14, 2006 | 05:48 PM
RANDY350Z's Avatar
RANDY350Z
Looks great, BTW did you know Kenwood has a back up camera?
Old Sep 14, 2006 | 08:55 PM
gt3's Avatar
gt3
Yeah, but it is too large to fit in the space in the area which I fitted the panny unit.
Old Sep 14, 2006 | 09:06 PM
RANDY350Z's Avatar
RANDY350Z
how did you connect it to the rear lights?
Old Sep 14, 2006 | 09:12 PM
gt3's Avatar
gt3
I tapped the reverse lamp wire near a wiring harness behind the driver seat below the small triangular shaped rear window. Check this thread in which Paul350z (thanks BTW) took a good photo of the wire:
LINK
Old Sep 18, 2006 | 12:32 AM
luke79's Avatar
luke79
we're waiting for the pics mate!
Old Sep 18, 2006 | 03:56 AM
gt3's Avatar
gt3
Sorry for the delay (felt sick all day )...here are the close-up pix and more detailed instructions. I will try to explain how I mounted the camera. It is somewhat difficult to explain so hopefully you will understand. I numbered the pix so you can follow the DIY below.
1. I took out the right license lamp, heat it up in the oven, and took it apart. I then slightly dremeled the upper casing and reglued the lamp 180 degrees turned around. I remounted the lamp housing to the car also 180 degrees turned around. This will provide more space between the hatch unlocking button and the license lamp for the camera.
2. I mounted a home made "L" bracket on the outer side of the camera with double sided tape. I then used the supplied bolt to mount the camera to the "L" bracket.
3. I drilled a hole the side of the hatch unlock button housing and then mounted the inner side of the camera with a bolt going through the hole. I added some velco just to be safe. This will require you to remove the hatch unlock button housing which is only accessible after you take off the rear bumper. The housing is mounted with 4screws if I remember correctly. This will also make the camera harder to steal and provide an added security measure.
Hope these pix and instructions help! Let me know if you guys have any ?s.
Attached Thumbnails Rearview Camera OEM style installed!!-closeup1-1.jpg   Rearview Camera OEM style installed!!-closeup2-1.jpg
Old Sep 18, 2006 | 04:18 AM
luke79's Avatar
luke79
thank you! that'll be more clear when I'll try to fit mine
Old Sep 18, 2006 | 04:29 AM
gt3's Avatar
gt3
Good luck on the install!!! Which camera did you decided to go with?
Old Sep 18, 2006 | 04:32 AM
luke79's Avatar
luke79
I have a friend who has a friend who lives in Japan. I'm trying to sorting out a good price for the Alpine. I have to wait for an answer and then make a choice. There's 100$ between the Alpine and the Panasonic one...
Old Dec 9, 2006 | 06:46 AM
luke79's Avatar
luke79
hey mate, I just got the HCE-C100. Before I begin the install, can you give me some directions on where to pass the cables from the bumper to the screen and where to fit the camera electric unit ? Thanks! ;-)
Old Dec 9, 2006 | 04:40 PM
gt3's Avatar
gt3
Sure thing, you will need to remove the rear bumper. I wired the camera wires through the area next to the license plate lights then cut a small hole in the center rubber grommet. Then remove the interior panel to get the wires through the hole in the grommet into the interior of trunk area. Then I ran the wires on the side of the spare tires to the existing holes on top of the cubby area. I put my video box in the passenger side cubby and tapped the reverse lamp wire behind the driver side seat belt area. I ran the power wires and the video cable via the center console area to the front. Hope this helps you.
Old Dec 11, 2006 | 04:23 AM
luke79's Avatar
luke79
thank you mate, I'll try to fit it this week-end
Old Mar 10, 2007 | 09:38 AM
  #38
jamaicanj's Avatar
jamaicanj
Great install.
Old Mar 20, 2007 | 08:17 PM
  #39
labelworkshop75's Avatar
labelworkshop75
hey im about to buy a camera but i have no idea which one to get. I'm looking for a good quality camera but not the most expensive one. Any opinions??
Old Mar 21, 2007 | 04:02 AM
  #40
luke79's Avatar
luke79
hello! I'm back since a long time...
Here are the pics of my setup, thank you gt3 for your directions!
http://www.youtube.com/watch?v=GA_WG4xikus
Alpine HCE-C100
