12" sub - faux floor install question
Old Jun 22, 2006 | 10:56 PM
ProfessorKan's Avatar
ProfessorKan
Default 12" sub - faux floor install question
I'm trying to build a 12" faux floor for the Z. Would I need at least 2" between the sub's coil and bottom of the box?
Does anyone have pics of an 12" faux floor install, without carpeting? Any advice would be greatly appreciated!
Old Jun 23, 2006 | 11:56 AM
JimRHIT's Avatar
JimRHIT
You'll need 1" between the back of the sub and the bottom of the box. I'll see whatI can dig up for pics.
Old Jun 23, 2006 | 11:20 PM
ProfessorKan
I heard a minimum of 2", but I can only afford 1.5" in my MDF floor setup.
PICS will be great, thanks!
Old Jun 24, 2006 | 09:06 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
i have some pictures of a 10, but a 12 would have easily fit there as well...i have about 1" below the magnet, but if you want to raise the floor more, you can easily get 2"...not that i think its necceesary:
Old Jun 25, 2006 | 03:51 PM
ProfessorKan
Thanks for the pics!
My sub is 6.5" + 3/4 MDF + 1" magnet space, that's about 8.25" total. So I would have the raise the floor 2 1/4" correct? I'm measuing from the top portion of the trunk (space before the strut / after the read speakers)
Old Jun 25, 2006 | 03:53 PM
ProfessorKan
btw. where did you ground the rear amps?
Old Jun 25, 2006 | 09:12 PM
dannichols's Avatar
dannichols
I got a 5.6" 12" back there without raising it at all. I think 1" clearance is enough. Also, the fake trunk liner, thin carpet and thick carpet will add nearly 1/2". I was able to get he sub flush with just using a 1/2" MDF riser ring. You may not have to raise it so much if you consider the carpet and use a ring above the box to extend the sub upward a bit.
