Does anyone else have this problem?
Old Jun 27, 2006 | 09:22 PM
woodstock300s's Avatar
woodstock300s
Default Does anyone else have this problem?
I installed a panasonic cd deck in my 04 and I have horrible radio reception, but everything is wired correctly. Any ideas to as what the problem might be? I am using the stock antenna, should I change it?
Old Jun 28, 2006 | 06:50 AM
ACI318's Avatar
ACI318
Make sure that you connected the blue wire for the power antenna. Also make sure that the antenna conector is pushed in all the way. If both of those are connected correctly plug in the factory radio and see if it gets good recption. Let me know what happens when you try these solutions and then I might be able to help you.
Old Jun 28, 2006 | 05:12 PM
mikew18's Avatar
mikew18
all newer nissans have verryy poor radio reception, you can get a magnified antenna that sticks to the inside corner of your windshield or do like myself and alot of other people...get xm radio...its shhhwweettt
Old Jun 28, 2006 | 07:02 PM
woodstock300s
thanks i'll try wat you said
Old Jun 30, 2006 | 08:18 PM
woodstock300s
when i put the stock hu back in...i get reception again
Old Jul 1, 2006 | 06:11 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
It's likely that the amplifier that's sitting in the rear right quarter panel isn't getting power.
Old Jul 1, 2006 | 06:19 AM
Derek's Avatar
Derek
Yeah I'm 99% sure thats your problem.
Old Jul 2, 2006 | 07:27 AM
ACI318's Avatar
ACI318
Make sure you have the blue power antenna wire connected comming out of the aftermarket head unit to the wiring harness adpator. If that wont fix your problem, u might just want to take it to a local businees for some help
Old Jul 2, 2006 | 09:36 AM
Brocken's Avatar
Brocken
good thing I don't listen to the radio much because I didn't hook that wire up in the harness...I didn't realize the Z had a powered antenna.
No wonder the radio sound crappy.
Old Jul 2, 2006 | 05:02 PM
woodstock300s
thanks alot guys
Old Jul 5, 2006 | 07:13 AM
ACI318's Avatar
ACI318
Did you get the problem fixed?
Old Jul 5, 2006 | 12:48 PM
woodstock300s
yes...it was the bue wire..thanks guys
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
