Help Asap!!!
Old Jul 7, 2006 | 06:37 PM
behjjeh's Avatar
behjjeh
Vendor - Former Vendor
Exclamation Help Asap!!!
i was installing JL 500\1 and Type R on to Stock HU.
i bought a FL LOC600 (LOC) and tap into two speakers..
but subs is not pumping!!!
i do get power light on amp, and subs are not pumping and i hear music coming out from sub. not loud... what is wrong???? please help!!!!
Old Jul 7, 2006 | 06:46 PM
Ichigo's Avatar
Ichigo
Have you adjusted your gains on the amp? Are there any dials or adjustments on the "FL LOC600 (LOC)"
Dont panic, if the amp is now, on its just a matter of setting the levels and gains
Old Jul 7, 2006 | 06:52 PM
sq40's Avatar
sq40
Check your Gains, Check your Grounds too. Are you sure you have the right speaker wires tapped (+ and -)
Old Jul 7, 2006 | 07:12 PM
behjjeh's Avatar
behjjeh
i believe so.. what's best way to find out which one is + or -.
and should i tap into just he right speaker?
Old Jul 7, 2006 | 07:56 PM
behjjeh's Avatar
behjjeh
here is two things i did..
one thing weird is both of speaker wires comes otu 6.something Volts..
i dont know which one is ground or hot..
please help!!
Old Jul 8, 2006 | 12:05 AM
702Fairlady's Avatar
702Fairlady
OK first thing to try is turn the gain up on the amp. If that doesnt work make sure you have all the + and - right. At the top of this forum page there is a wiring color code thread. If you have a crappy ground it can sometimes happen but sometimes it sparks if it isnt good enough.
I have never really liked LOC's. It used to suck putting them in cars.
Are you trying to keep the stock look in the dash by using the stock HU? Because if your putting a $700 amp and $300 sub in your car, might as well go for the gold and spend 150-200 on a new deck that has some good voltage preouts (4V or more) you wont need a LOC for. Plus you get more control of the audio system with aftermarket HU's. Just my opinion.
Old Jul 8, 2006 | 12:12 AM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
I have the same amp, it HAS to have a good ground to work. Double check it.
Old Jul 8, 2006 | 05:32 AM
sq40's Avatar
sq40
From Your Diagram, You seem to not have the Cap hooked up to anything?
Power should go from the Batterys + to the + on the Cap and then from the cap's + to the Amp. The Ground should Be to a Clean, Bare Metal Surface on the "Frame" of the car. The Amp's Ground Should Also be to a Clean, Bare Metal Surface on the Frame of the Car.
Hook a MM up to the Speaker Wires with the Volume up a bit. You will see ramdom, low Voltage. If your Multi Meter reads Positive Voltage, you have the Polarity Right, if your meter reads negative voltage, you are hooked up reverse. Another way to test this is to hook a wire to the speaker's terminals and plug in a 9v Battery. If you have the polarity right, the speker's cone will move out. If it is reversed, it will sink in. You can then compare notes as to what wire was plugged in to what terminal to determin what is what.
As a final thing, you can determin your car's wire colors by calling crutchfield and asking. 9/10 they will tell you, even if you didnt buy something.
Old Jul 8, 2006 | 06:23 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Ah, no. The audio output of an amplifier is alternating current. Music is made up of of complex sine waves meaning that there is as much deflection in the positive direction and the negative one. Connecting a VOM up to a speaker wire on an AC scale ought to display some voltages.
The 9V battery trick is correct and the one I've been using for the last 30 years.
I'll bet a dollar - $0.95 that the gains aren't adjusted and $0.05 that one of the subwoofers is wired out of phase.
Old Jul 8, 2006 | 08:09 AM
behjjeh's Avatar
behjjeh
ah....... i just wired LOC to Boss sub wire... and works.. damn..
how lucky im...
and... on that diagram.. ur saying cap is not doing anything?!
Old Jul 8, 2006 | 08:24 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
how lucky im...
Sure it is - it's connected to the amplifier via that fuse ... I would rather see that fuse relocated to put it as close to the battery as possible - that way it's protecting as much of the wire as possible - including those connections to the cap.
Old Jul 8, 2006 | 02:46 PM
behjjeh's Avatar
behjjeh
koo~~~ thanks!
etkms
Jun 19, 2022 06:30 PM
LunchBox20
Oct 20, 2015 10:22 PM
