Can someone w/ 06 service manual confirm wire color for me?
I need the color for the 12v lead going into the Yaw control sensor on a 2006.
The yaw control sensor is located beneath the lower-center console, behind the shifter.
I have an older service manual and it shows OR (Orange) as the 12v lead.
However my 06 does not have solid orange going to this plug. Only Orange w/ White stripe.
If you have an 06 manual would you mind double checking the VDC harness diagram and confirming the 12v color on the "Yaw Rate/Side G Sensor"?
Thanks!
-Smoky
Thanks!
-Smoky
My 2006 manual shows the following:
W/R (white/red) --> (pin 6) GND
OR (orange) --> (pin 3) 12V
LG/R (light green/black) --> (pin 4) OUTPUT DRS
L/B (blue/black) --> (pin 1) REFERENCE
Y/B (yellow/black) --> (pin 2) BITE
LG (light green) --> (pin 5) OUTPUT BS
Hope this helps
Hope this helps
Yes that was checked. The readings and the behavior are all 100%. It was just the white stripe (which I think now may just be a "stretch" in the rubber they used, and my wire just got into it).
