bose sub problem
Old Jul 27, 2006 | 11:35 AM
acekicker's Avatar
acekicker
Default bose sub problem
I just bought this 03 touring, and I've searched with no luck about this sub problem. It didn't work, so I opened
the enclosure took the sub out, and wiggled the wires with no luck. Then all of a sudden it came on. Worked for about 2-5 minutes and cut off again. I moved all the wires around with no connection ever occuring. Does anyone know what is causing this to happen?
Thanks
Old Jul 27, 2006 | 12:05 PM
tmounk's Avatar
tmounk
I haven't had any problems with mine yet, but still it's just a bose. I plan on getting a box and subs later. The new cobalt has more bass than my whole system with the bose sub.
Old Jul 27, 2006 | 12:20 PM
ZBigDog's Avatar
ZBigDog
^you're right, my girl has one and it puts my blowse to shame. I'm addin the infiniti bass link, its an easy and cheap install that will sound great in the coupe. they retail for $300 but you can find em online for $200. they also will fit where the bose sub went if u wanna keep the limited space you have as it is.
as per your problem cant help ya, sounds like a connection problem. if u just bought it bring it back and complain about it.
Old Jul 28, 2006 | 02:35 PM
VO...'s Avatar
VO...
Administrator
Thanks
Sounds like a metallic fault problem in the wiring or connector. You'll have to play with it and do alittle trbl shooting to figure out what part is bad, then replace it. Thats it...
Old Jul 28, 2006 | 03:10 PM
JimRHIT's Avatar
JimRHIT
I'm proud to say I worked on that system One of, if not THE, best all-around (affordable) OEM system on the market
The most likely scenario is that the tinsel leads (aka the wires from the basket to the cone/coil) are worn over time. Cheap OEM systems rarely coat these, and over time, yes only 3 years, or hard use .. these fatigue and fail quite often. You can put a spot of solder on there if this is the case ... just be careful not to burn the spider.
Jim
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
