Mono Amp
Old Aug 4, 2006 | 12:38 PM
twotonez's Avatar
twotonez
Question Mono Amp
What is the speaker wire setup for a mono amp, and how do mono amps work?
Old Aug 4, 2006 | 01:32 PM
tienlo's Avatar
tienlo
possibly wrong forum? if you mean monoblock amp for a car, i'm not sure if vacuum tubes are a good idea for a moving vehicle?
if you want to know how to wire up a mono amp (eg class D) for a subwoofer, it's easy as... there should be L & R coax in, and a single channel speaker out.
Old Aug 4, 2006 | 01:37 PM
twotonez's Avatar
twotonez
Question
Yeah I know a little bit about amps but I guess I was just wandering what a mono amp means exactly.
Old Aug 4, 2006 | 02:04 PM
VO...'s Avatar
VO...
Administrator
It's got VD...
Old Aug 4, 2006 | 02:22 PM
Built2shredZ's Avatar
Built2shredZ
A mono amplifier makes a great choice for powering subwoofers. They're specifically designed for low-frequency reproduction, with built-in bass boost and low-pass filters. Class D mono amps are often a good choice — they draw less current, produce less heat, and are more efficient than conventional amp designs. You can use a 2-channel amp for powering two subs, or bridge the amp to single channel operation for a single woofer. Likewise, a 4-channel amp can be bridged to 2-channel mode to power a pair of subs. How much power you need depends on the subwoofer(s) you'll be using, but figure on at least 150-200 watts per sub for 10" or 12" subwoofers.
Old Aug 6, 2006 | 06:36 PM
twotonez's Avatar
twotonez
Thanks built2shredz that cleared it up.
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
cashmoney03
Sep 27, 2015 05:24 PM
Shane86
Sep 17, 2015 05:33 PM
