Stupid question of the Day
Old Aug 4, 2006 | 05:41 PM
freemanjc's Avatar
freemanjc
Default Stupid question of the Day
Can I run a Alpine MRD-M605 in series with two "10" inch subs or do I have to buy two Mono Amps to run each sub.
If the answer is yes, what ohm impedance do the subs have to be to run them in 2ohm load in sereis to both subs!
I think I meant to say Parallel vice sereis! Basically I want to use one Mono amp with two subs at 2ohms. Can somebody tell how to do that if possible!
The amp i am looking at is Alpine MRD-M605. If I can does that divide the watts between the subs or are both subs running the same RMS wattage.
R,
Free
Old Aug 4, 2006 | 05:55 PM
clkwrkorg36's Avatar
clkwrkorg36
if single voice coil they need to be 4 ohm wired parallel, if they are dual voice coils they should be dual 2 ohm wired to 4ohm, and then paralleled.
Old Aug 4, 2006 | 06:04 PM
freemanjc's Avatar
freemanjc
Which f the two do I need to get! I really stupid when it comes to this!
Alpine SWR-1042D
10" 1500W Dual 4-Ohm Subwoofer
Alpine SWR-1242D
12" 1500W Dual 4-Ohm Subwoofer
http://www.onlinecarstereo.com/CarAu...facturerID=611
Thanks
Old Aug 6, 2006 | 10:24 AM
toyoter91's Avatar
toyoter91
you want to get single 4 ohm subs.
issyz
Jul 2, 2017 03:04 PM
kyin
Oct 15, 2015 05:54 AM
nanotech
Oct 2, 2015 05:02 AM
