Whats the differance in LCD
I also want to install a 7" lcd in the cubbie but what kinda is good and whats the differance between the Ferin., and the Xe whatever its called?
Originally Posted by JimRHIT
Xenarc? Lilliput?
Defferences .. well ... contrast, brightness .. off axis viewing etc.
Lilliput
Screen Size:
Diagonal 7 "
Dot Resolution (RGB):
800(H) x480(V) = 1,152,000 (dots)
Aspect Ratio:
15:9
Contrast:
250:1
LCD Brightness:
350cd/m2
Viewing Angle: 45/60(U/D),65/65(L/R)
Operating Voltage: DC 11-13V
Power Consumption:
<10W
Dimension (mm):
183W x 125H x33D
Weight (kg):
0.430
Xenarc
Model #: 700TS / 700TSV
Screen Size: Diagonal 7" (16:9)
Physical Resolution: 800 (H) x 480 (V) WVGA
Supported Resolution: 640 x 480 ~ 1600 x 1200
Dot Resolution: 2400 x 480 = 1,152,000 (dots)
LCD Brightness (w/o Touchscreen)*: 400 cd/m²
Display Brightness (w/ Touchscreen): 330 cd/m²
Touch Screen Interface: USB port
Operating Voltage Range: DC 11V ~ 24V
Power Supply: DC 12V
Power Consumption: <8W
Operating Temperature: 23°F ~ 158°F
Storage Temperature: -22°F ~ 185°F
Dimension (in): 7.75W x 4.75H x 1.38D
Weight (lb): 1.28
FCC, CE, E13 Certification
18 Month Warranty
Available in Silver or Black
Screen Size:
Diagonal 7 "
Aspect Ratio:
15:9
Contrast:
250:1
LCD Brightness:
350cd/m2
Power Consumption:
<10W
Dimension (mm):
183W x 125H x33D
Weight (kg):
0.430
Xenarc
Weight (lb): 1.28
18 Month Warranty
