Computer Lock-out...
Old Aug 25, 2006 | 09:09 AM
Dr. RPM's Avatar
Dr. RPM
Default Computer Lock-out...
I'm repairing an '03 Track version salvage. It was hit passenger front - hard enough that I've had to remove the front clip and section in a new right front frame rail and inner fender rail. I had to remove the ECU/dash/wiring harness, etc. The engine ran well before the car came apart, but now will only turn over/dash lights up/etc. but won't fire. Anyone been this deep into a Z?
Old Aug 26, 2006 | 08:39 PM
KPierson's Avatar
KPierson
Are you using the same ECU and key that came with the car?
Do you have everything plugged in?
There really could be 1000 different things keeping the car from running.
You may try cranking it for an extended period to see if it throws a CEL.
Old Aug 27, 2006 | 08:34 AM
Dr. RPM's Avatar
Dr. RPM
Yup...same ECU/column/key, etc. I'm just wondering if I may have a dead short somewhere? Will not having the mass-air plugged in keep it from running? I'm just trying to get it "mostly together" so I can paint it and then finish assembly.
Old Aug 27, 2006 | 09:01 AM
KPierson's Avatar
KPierson
Not having the MAF should put the car in limp mode, but it should still start. I would check injectors, coils, crank and cam angle sensors.
Old Aug 31, 2006 | 05:54 AM
Dr. RPM's Avatar
Dr. RPM
Thanks, I'm beginning to suspect the crank sensor, cuz I've checked almost everything else...
Old Aug 31, 2006 | 06:12 AM
KPierson's Avatar
KPierson
It will still start with a bad crank sensor, but the ECU will use the cam angle signal to determine firing/injections. I believe at that point it switches to batch injection and injects twice per cylinder. Lets the car run, but not very well....
Old Aug 31, 2006 | 06:33 AM
teh215's Avatar
teh215
Is it possible that the immobilzer in the key got damaged?
Workshop12
Mar 23, 2020 01:45 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
TrboMike
North East
Sep 28, 2015 06:36 PM
Twiztids4
Tuning
Sep 10, 2015 04:02 PM
