Got my wires crossed...
Old Sep 3, 2006 | 07:26 AM
sry110's Avatar
sry110
Default Got my wires crossed...
Here is my problem, and hopefully someone can offer some insight...
I had a new audio system installed in my Z recently which comprised a new head unit, new front speakers w/ separate tweeters, new rear speakers, subwoofer, and amp. The 5-channel amp powers the fronts, rears and subwoofer. My problem is that when I use the Fade (front/rear) function in the head unit, the sound does not simply fade front to rear. Instead when I fade to the Front, the sound goes to my front drivers side and rear passenger side. Similarly when I fade to the Rear, the sound goes to the front passenger side and rear driver side. So the only way I can get even sound is to leave it right in the middle.
You might have guessed by the fact that I had this system installed by someone else that I am no expert on car audio; however, I would like to fix this problem myself. So before I go tearing apart the car to access the head unit and/or amp, can anyone offer suggestions as to where the wires might be incorrectly connected to cause this type of problem? Is this something that could possibly be caused be a defective head unit? All of its other features seem to work fine.
Please help!
Old Sep 3, 2006 | 07:40 AM
TreeZ's Avatar
TreeZ
it sounds like the wires got crossed coming out of the amp. if you have access to the amp, switch one of the sets connected to the rear outputs to the right front output (since that's the one that is not working up front). then figure out by trial and error which side is which for the rear for the remaining two sets that aren't connected to the front at this point, since i'm going to assume your wires aren't marked. and that's another thing, once you figure it out, you may want to mark them, just in case.
Old Sep 3, 2006 | 08:49 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
sry110 has it right. Just unplug the RCA cables from the amplifiers and then adjust the volume to front right and plug the RCA cables in until the front right speaker plays music ... continue the process until you've got it done.
350Z_Al
Oct 29, 2020 07:44 PM
bcoffee20
Nov 19, 2015 06:39 PM
nanotech
Oct 2, 2015 05:02 AM
cashmoney03
Sep 27, 2015 05:24 PM
Beater350z
Sep 9, 2015 03:36 PM
