Sub tuning help...Stealthbox
Old Sep 15, 2006 | 04:47 AM
Zrated's Avatar
Zrated
Default Sub tuning help...Stealthbox
I have the JL Stealthbox w/ the JL 500/1. Does anyone have a suggestion to help tune out the "boomyness" ???
Thanks.
Old Sep 15, 2006 | 05:34 AM
LayinLo's Avatar
LayinLo
What are the settings at right now?
Old Sep 15, 2006 | 08:12 AM
Zrated's Avatar
Zrated
Q is set to about "1.5"
Center Frequency Control is about "50"
Boost is "+4 db"
LP is "100" w/ slope "18 db"
Not sure if I need to turn the Infrasonic Filter on to help.
Old Sep 15, 2006 | 09:52 AM
JimRHIT's Avatar
JimRHIT
Turn off the Center Freq and boost.
LP it at 80Hz
Old Sep 15, 2006 | 09:54 AM
sisco534's Avatar
sisco534
+1 80Hz is best setting
Old Sep 15, 2006 | 11:38 AM
Zrated's Avatar
Zrated
JimRHIT, so I should turn the amp EQ off all together? That will also kill the "Q". Is this what your suggesting? I'll also set the X-Over to 80Hz.
Thanks guys.
Old Sep 15, 2006 | 12:26 PM
JimRHIT's Avatar
JimRHIT
Yes ... here is an example of what you are doing ... you are adding a boominess that is unecessary with that EQ
My advice is to turn it off altogether
Old Sep 15, 2006 | 12:31 PM
JimRHIT's Avatar
JimRHIT
a better example.
In these you can see that the sub is playing frequencies above 100Hz with full authority (headache bass) . The 80HZ XO and no eq alleviate this problem by at least 5dB (almost twice as "quieter/cleaner")
Try this out .. let me know how it works for you.
- Jim
Old Sep 15, 2006 | 12:52 PM
VO...'s Avatar
VO...
Administrator
LP it at 80Hz
+1 on the Low Pass @ 80Hz. It'll filter out what is designed for mid-bass drivers.
Old Sep 15, 2006 | 05:26 PM
Zrated's Avatar
Zrated
Ahhhh.. This is good stuff! OK, I set my LP to 80Hz for the sub. I also killed the EQ on the amp. I tried both ways with Alice in Chains, Jar of Flies. Definitely cleaner. I also set my front and rear speakers to HP at 63Hz (next lower step below 80Hz on my HU). It has a smoother sound now. VERY nice. Thanks.
Before HP=80
LP=100
Now
HP=63
LP=80
Any thoughts on the HP filter setting?
2ndchanceZ
Oct 26, 2015 08:03 PM
nanotech
Oct 2, 2015 05:02 AM
KOF
Tuning
Sep 30, 2015 04:09 AM
