Dual Voice Coil "Math"
Old Sep 17, 2006 | 06:34 AM
RiotWithin's Avatar
RiotWithin
Default Dual Voice Coil "Math"
I just noticed a dual 2 ohm sub can either have 1 ohm or 6 ohm if I remember correctly. That doesn't make sense to me. I am thinking of doing an MTX woofer setup with a matching amp. I can get the MTX 10" woofer in a single 4 ohm voice coil (which I would imagine puts out 4 ohms), or the dual 4 ohm voice coils. (which I am hoping if wired correctly allows for 2 ohm resistance).
Here are the basic specs for RMS
MTX 8500 T8510-44 (Sub) - 500 watts RMS
MTX Thunder TA91002 (Amp) - 2x500 @ 2 Ohms
Wouldn't this work in my favor???
Old Sep 17, 2006 | 06:48 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
You've got your math wrong.
In series resistances add so 2 + 2 = 4 ohm
In parallel resistances divide so 1 / 1/2+1/2 = 1 ohm
When dealing with two equal resistances just remember that the total resistance is going to be have of one of the loads. Makes sense because now the power has two paths to travel through meaning that the total resistance has to go down.
So yes, if you wire your dual four ohm sub-woofer in parallel (negative to negative and positive to positive) then you'll end up with a two ohm load for your amplifier which will thank you for the reduced load by putting out more power for you.
Old Sep 17, 2006 | 07:51 AM
MUZZY's Avatar
MUZZY
+1
remember series is add and parallel you divide. so a dual voice coil will give you 4ohm in series. a dual voice 2ohm coil will sound beter than a single coil 4ohm speaker. GO DUAL COIL PLZ
Old Sep 17, 2006 | 07:53 AM
MUZZY's Avatar
MUZZY
also if your speakers can handle 500 watt rms then get a stronger amp. usually a 1000 watt amp will only have an rms of 300-400. so if you are going to run 2x 500watt rms speakers get atleast a 2k watt 2ch amp.
Old Sep 18, 2006 | 12:24 AM
limeg35's Avatar
limeg35
This site's illustration might also help...
http://mobile.jlaudio.com/support_pages.php?page_id=161
Old Sep 18, 2006 | 09:50 AM
VO...'s Avatar
VO...
Administrator
Here you go...
Attached Thumbnails Dual Voice Coil "Math"-a1.jpg   Dual Voice Coil "Math"-a5.jpg
Old Sep 18, 2006 | 06:50 PM
DIGItonium's Avatar
DIGItonium
Or for parallel, product/sum if it's easier to do that in your head.
Uriyo_
Sep 8, 2021 08:46 AM
sales@czp
Sep 23, 2019 03:30 PM
