Help with Alpine CDA-7998 install
Old Mar 7, 2003 | 07:03 AM
cobf32's Avatar
cobf32
Question Help with Alpine CDA-7998 install
Has anyone installed a CDA7998 or the other similar alpine HU which has the motorized face themselves? I have seen some installs on this board using the Metra kit, and I decided to try it myself.
I keep having a problem with the unit hitting the round part of the dash, things not lining up etc. What a PITA!
My ?? is did you use the ISO mounts or the "cage" and what is the best way to do this?
THANKS for any help out there!
Silverstone Performance
Phoenix AZ
Old Mar 7, 2003 | 08:16 AM
onecoolee's Avatar
onecoolee
You cannot flush mount this head unit in the metra kit due to the rounded front of the pocket under the single din mount. I used a motorized face head unit, a Pioneer Premier DEH-P840mp. I tried initially to flush mount this unit like you did...it will not open like this.
So, to fix this problem you have 2 options.
1. Flush mount the head unit, and painstakingly file away the rounded front part of the pocket. THis will fix it.
2. The easier method, and the means I chose was to not flush mount the head unit. Instead I made a piece of trim ring cut from 1/8" thick abs plastic (black), and used that as a buffer between the collar of the head unit and the metra kit. THis gave the head unit the extra depth that it needs to open up and do its thing.
If you search around here more, you will find that others using motorized faced head units ran into the same problems. Its not a major deal to fix, and should cost you much money (if anything at all).
Good luck.
Old Mar 7, 2003 | 07:57 PM
cobf32's Avatar
cobf32
Thanks for the info.
I think I will try the spacer method because the HU I have comes straight out, then up, so the top hits the rounded plastic just below the nav door, not the bottom of the Metra kit.
I messed with it for hours last night, will try again this weekend
Phoenix AZ
Old Mar 7, 2003 | 08:46 PM
Lightning's Avatar
Lightning
i used the spacer method on my 7998 and it worked perfectly... i made it realllllly close, though, but it works nicely.
dcains
Nov 11, 2015 11:36 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
