low radio signal Help!!!!!!!!!
Old Sep 23, 2006 | 08:59 AM
dragone2717's Avatar
dragone2717
Default low radio signal Help!!!!!!!!!
Yo.......... Man at last I finally got my radio in. And I couldn't have done without the threads on this site. Thanx alot. But now I came into a problem. I installed an Clarion in-dash screen seen in the pics. And when all said and done. I get no no radio signal. I get stations but when I go to change the station it keeps going-n-going it won't stop at the next radio station. So I have to play the get lucky with the button game. Is it the car, I double checked everything. All is good. Do I have to connect the power antenna?
Please HELP!!!!!!!!!!!
http://i61.photobucket.com/albums/h6...23-06_1126.jpg
http://i61.photobucket.com/albums/h6...23-06_1127.jpg
Old Sep 23, 2006 | 06:42 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Did you run power to the factory antenna amplifier back in the left rear quarter panel? The amplifier needs +12VDC and is mounted just under the antenna in the trunk. The wire is up under the dash as it get's power from the stock head end.
The color code is G/W = Green with White stripe.
You can often feed the antenna from the power antenna signal of the aftermarket head end - often a blue wire.
350Z_Al
Oct 29, 2020 07:44 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
