Bose wiring?
Old Sep 26, 2006 | 10:35 AM
bklusa1's Avatar
bklusa1
Default Bose wiring?
Does the bose stereo require a different wiring harness than the regular stereo, as far as putting a new head unit in?
Old Sep 26, 2006 | 02:12 PM
reptile718's Avatar
reptile718
Yes you need a converter and the wiring is slightly different. I bought mine from peripheral electronics.
Old Sep 26, 2006 | 04:09 PM
bklusa1's Avatar
bklusa1
Default $$$
How much does this converter run? Does it just adapt the in car wiring to the new head unit harness?
Old Oct 1, 2006 | 06:23 PM
bklusa1's Avatar
bklusa1
Are you absolutely positive that I need a coverter of some sort. I just got off the phone with crutchfield and they said I 100% do not, because only some bose systems have individual amps on the speakers, and in this case we don't? Just want to make sure I'm ordering the right stuff online here..... thanks! Also, with the stock subwoofer, how is that ran with the stock wiring, is it just connected with the rear speakers, or does it have its own connection? I'm hooking up the Kenwood KDC-MP528 that I have here, just want to know of any roadblocks I'm going to run into during the process....
Old Oct 2, 2006 | 01:46 PM
iLLeSTBBoY3's Avatar
iLLeSTBBoY3
You don't need it, however it is recommended that you replace everything. I currently have an aftermarket stereo, sub/amp, and stock BOSE subwoofer speakers and amp. Just buy the metra wiring harness and your good to go.
Old Oct 3, 2006 | 01:19 PM
bklusa1's Avatar
bklusa1
Default Metra?
The metra wiring harness does the same thing as the peripheral correct? I just got off the phone with a local shop and the they recommended metra also. It's 20 bucks vs 100 for the peripheral. They said the metra sounds better anyhow, cleaner.
m_0g
Jun 3, 2021 10:05 AM
350Z_Al
Oct 29, 2020 07:44 PM
nanotech
Oct 2, 2015 05:02 AM
cashmoney03
Sep 27, 2015 05:24 PM
