Door speaker mounting
Old Oct 3, 2006 | 08:42 PM
arejohn's Avatar
arejohn
Default Door speaker mounting
I just completed updating the door speakers in a non-bose system and made some observations that have inticed me to consider making an adapter that would provide for mounting the speakers to the door trim.
-An adapter is required if you mount to the door or the trim panel.
-Mounted to the trim the sound is directed out of the door without reflecting between the door and trim panel which should provide increased efficency and reduced distortion.
-Speaker could be centered within grill opening.
-Increase space to clear window glass.
Any comments for or against greatly appreciated.
Old Oct 3, 2006 | 09:02 PM
SS21CA's Avatar
SS21CA
1 What material would you use, 2 how thick would the spacer be, and 3 could you make an angled spacer that will allow speakers with greater depth to clear the window?
Old Oct 4, 2006 | 06:02 AM
james840a's Avatar
james840a
Id recommend the door speaker pods. I just finished installing mine i created and it is a night and day difference compaired to the speaker behind the door panel/grill. Check out my thread on the my door pods.
https://my350z.com/forum/audio-and-video/217767-created-my-door-pods.html
Just remember if you keep it behind the Oem grill in the door, the grill only has half the holes punched out so youd have to drill each hole out.
Old Oct 4, 2006 | 06:34 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Have a close look at those speaker grills before you insist on mounting the speakers in the very center of the "grill". As you can see from this picture of my '05 the grill holes are not all cut out. The mid-bass/mid-range frequencies aren't affected much if any by these holes but a tweeter would be.
Old Oct 11, 2006 | 02:25 PM
L33TZOR's Avatar
L33TZOR
why do i not see the point of springing 280 bucks for 40 dollar speakers???
Old Oct 11, 2006 | 08:19 PM
z350boy's Avatar
z350boy
If you want to improve the sound of the door speakers I would recommend you purchase a set of door pods from wickedcas.com. These pods mount on the door over the speaker grille. Not only do they give a really exotic and custom look to your vehicle, they also redirect the speaker giving a more natural clearer sound.Just my 2c.
3vilbunny
Jul 18, 2017 05:10 PM
kyin
Oct 15, 2015 05:54 AM
