****Alarm Issue****
Old Oct 9, 2006 | 01:07 PM
TayTaythatsme04's Avatar
TayTaythatsme04
Default ****Alarm Issue****
I like the stock alarm and keyless entry stuff, but Im having this reoccuring problem were for no reason at all the alarm goes off. Sometimes over and over and sometimes it will not happen for days. Whats wrong with this thing or . . .
I have a viper (the top line one) w/ report start, all the expandable buttons, hatch pop, doors, windows that I can switch to. But are any of the Z's window modulals or hatch latch able to work with the aftermarket stuff.
Need some help or opinons with this, whats the fix for this stupid thing or should I switch to the viper unit
Also I would be as pissed if the alarm didnt flash my brand new 8000K HIDs,
what a dumba$$ that thought it would be smart to flash the HIDs blubs
anyway
Thanks
T
Old Oct 9, 2006 | 02:30 PM
ofl0926's Avatar
ofl0926
i have the same alarm and i had the same issue and what i did was i disconnected the battery for a couple of minutes and the problem stopped
Old Oct 9, 2006 | 02:52 PM
TayTaythatsme04
I disconnect the battery everytime when I install stuff, I dont think thats it but I will try it.
T
Old Oct 10, 2006 | 12:41 PM
james840a's Avatar
james840a
I have the Viper 791XV and dont have any issues. When your alarm goes off, is it windy out? I know if the impact/motion sensor is set to high that the wind could set it off. Wait a minute re-read your post, are you having proplems with the factory alarm or the Viper unit?
Old Oct 10, 2006 | 07:21 PM
KPierson's Avatar
KPierson
If your OEM alarm is going off randomly most likely it is caused by the hood pin. Open the hood, inspect the wiring and also the fitment of the sensor itself. If it is loose, or if the wires have any corrosion on them then there is your problem.
Old Oct 10, 2006 | 10:02 PM
TayTaythatsme04
Hood thats probably it I total f***ed that thing up to get my new hood to fit right
Thanks
T
Old Oct 10, 2006 | 10:59 PM
702Fairlady's Avatar
702Fairlady
My clifford goes off for no reason at all. Does it about 1 time a week. Just goes off and doesnt stop until i disarm for like an hour then put it back on
