New CarPC project Question
Old Oct 13, 2006 | 09:17 AM
pushing4wardbac's Avatar
pushing4wardbac
Default New CarPC project Question
I have been collecting parts for the last few weeks and plan on doing a car PC install. I have the PC built and the screen ready and am trying to decide where to mount my Xenarc 700TSV. I am thinking nav cubby is going to be alright.
At the same time I will be installing new speakers and two amplifiers to drive the front and back speakers. How does using the speaker level input from the HU sound into an amp with speaker level inputs? Should I use a line output converter instead? Or is that what is built into the amp? Should I use my clarion EQ?
If anyone can answer any of these questions it would be much appreciated
Old Oct 13, 2006 | 09:39 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Q1) Should I use a line output converter instead? Or is that what is built into the amp?
A1) Yes, the amplifier has the same circuit installed.
S2) At the same time I will be installing new speakers and two amplifiers to drive the front and back speakers.
A2) Why not go with a four channel amplifier vice a pair of two channel amps.
Q3) Should I use my clarion EQ?
A3) Depends, if you do you'll have to convert the speaker level outputs to line level inputs for the equalizer. Or find a head end that has line level outputs.
S4) I am thinking nav cubby is going to be alright.
A4) Sounds good. There's enough room in there and the heat load isn't too bad. If you're concerned mount a fan or two to blow air in and out of the cubby dumping the air into the rather large area that the cubby sits inside.
Old Oct 13, 2006 | 06:07 PM
pushing4wardbac
Thanks, you answered all my questions.
350Z_Al
Oct 29, 2020 07:44 PM
issyz
Jul 2, 2017 03:04 PM
