Another Non-Z install for you guys :) IS350
Old Oct 26, 2006 | 05:02 PM
16psibrick's Avatar
16psibrick
Simplicity in Sound
Default Another Non-Z install for you guys :) IS350
alright, just got this car done, a new 06 is350. this is my first attempt at this car so it took a little longer but it turned out pretty good i might say
goals:
1. great sound quality with the stock nav headunit retained (found that the stock system does NOT do much eqing)
2. completely stealth with some show factor
so lets get started.
First the headunit and amp of the stock system is plugged into the inputs of an audiocontrol LC8, the signals are summed and provide the RCA signals for the amps.
Front stage: a set of DLS ultimate UR36i 3 way component set is used. the 6.5" midbass is sealed in the stock lower door location, and tiny kick panels are fabricated housing the midrange and tweet, it clears the foot brake with ease and provide a very nice and high stage with very very solid center image:
the rear stock components are left stock so lets move ont o the trunk
like i said, stealth is the key, here is what hte trunk looks like when opened, the KINK in the carpet is NOT from the system, its from being folded int he backseat for four days normally the carpet would lay completley flat...
pull off the carpet you see a vinyl fake floor, with vinyl cover in the back and a grill mesh on the front hmm why the strange looking grille?
with all the covers off, the system is revealed.
in the back, two alpine amps supplied by the car customer flank a set of DLS ultimate crossovers. and upfront, a quartet of Elemental Designs EU700 6.5" subs reside in a fiberglass spare tire well enclosure, both are trimmed in sude
the reason why the EU 700s are chose is becuase the well of the IS is pretty shallow and features a big center crossob brace this foursome certainly puts out enough bass to shake the rear view mirror with authority!
now some behind the scene photos:
fake floor off showing everyhting, notice how tight everyhting is, the LC8 is secured against the back trunk wall int he well lol
stock 8" was removed from the rear deck to get more bass into the cabin:
here are the front stage midbass install, first a cup was made, then put into the door, new speaker wires are run into the door, and then the entire door was sealed and dampened
here the spare tire well box in construction, you will see what i mean by irregularly shapped and not very deep:
Old Oct 26, 2006 | 05:15 PM
JokerDev's Avatar
JokerDev
wow, very nice work
Old Oct 26, 2006 | 06:11 PM
RANDY350Z's Avatar
RANDY350Z
If you retain the Nav, is it possible to install a single din flip out monitor where the audio controls are?
Old Oct 26, 2006 | 06:25 PM
16psibrick's Avatar
16psibrick
Simplicity in Sound
you canisntall a single flip out below that i believe, someone makes a custom kit
Old Oct 26, 2006 | 09:12 PM
dtak59's Avatar
dtak59
Very nice, very clean install. Did four EU-700's provide enough bass? I have two in the Z, and the bass is far from loud. I would imagine that the subs being far back in the trunk, and having to travel through the seats, the bass would be a little lacking in an IS.
Old Oct 26, 2006 | 09:27 PM
16psibrick's Avatar
16psibrick
Simplicity in Sound
not at all, everyone whos heard it thought it was at least a high powered 10...how do you have your EUs installed?
b
Old Oct 26, 2006 | 10:28 PM
gt3's Avatar
gt3
Awesome install...your work is simply amazing.
Old Oct 27, 2006 | 05:24 AM
Lsmith9523's Avatar
Lsmith9523
16psibrick,
Wow, nice install...Great attention to detail and love the fact you can still use the trunk...
Old Oct 27, 2006 | 09:42 AM
drifter23's Avatar
drifter23
16psibrick has done it again nice and clean install.
Old Oct 27, 2006 | 10:34 AM
superppwZ33's Avatar
superppwZ33
another sick install
nice work
b.t.w. 4 x eu-700 with a decent amp/enclosure will provide a lot of bass
Old Oct 27, 2006 | 12:14 PM
OffsetZ33's Avatar
OffsetZ33
What amp is running that frontstage?
Old Oct 27, 2006 | 01:18 PM
16psibrick's Avatar
16psibrick
Simplicity in Sound
powering from the stage the alpine 4 channel mrv 345 i think? bridged
b
Old Oct 27, 2006 | 02:17 PM
OffsetZ33's Avatar
OffsetZ33
See, now Im confused because dont the 4 channel alpines have different power outputs on their channels, so they cant really be bridged? I want to use an alpine mrv for my front stage (only need 2 channels @ 100w rms), but it looks like once you bridge them the 1/2 channels put out different power than the 3/4 channels. Will this still work?
Old Oct 27, 2006 | 04:43 PM
16psibrick's Avatar
16psibrick
Simplicity in Sound
hmm i see hwat you mean by the specs, but when bridged it, right and left was compeltely balanced...not a problem at all, true center image...hmmm bizarre
and this list from alpine itself doesnt seem to make any sense..
http://www.alpine-usa.com/en/product...model=MRV-F345
Old Oct 27, 2006 | 10:26 PM
dtak59's Avatar
dtak59
well, initially, i bought the EU's to be installed in the stock rear speaker location and after reading bad reviews about installing subs in the stock rear speaker location, I decided to make a box with .33 cu ft. i faced the box toward the rear and the EU's provides a decent amout of bass but it didnt seem like it was as good as all the hype it was getting.
Old Oct 28, 2006 | 08:19 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
.33 cub feet each or .33 cub feet total?
and how many watts did you throw at them?
b
Old Oct 28, 2006 | 05:18 PM
OffsetZ33's Avatar
OffsetZ33
How many watts rms does it do when bridged like that then?
Old Oct 28, 2006 | 09:02 PM
OffsetZ33's Avatar
OffsetZ33
This thread seems to say that if you bridge the 1/2 channels you still only get 75w rms, but the 3/4 gives you 300w rms - which should have an effect... Now Im really confused
http://www.caraudioaustralia.com/for...howtopic=59978
Old Oct 30, 2006 | 07:48 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
yeah its very strange...but i can honestly tell you when its bridged, and gains set even, its exactly balanced with a solid center image...weird... i will check it again when ew tune the car further in a week or so
b
Old Oct 30, 2006 | 08:32 PM
RANDY350Z's Avatar
RANDY350Z
Do you know who makes the custom kit, I did a search and found no results.
