Help installing Kenwood DDX-7015
Can someone show me how 2 install this deck?
I got all the equipment the wiring harness, PAC OEM ROEM-NIS2.
But the problem is that i dont no how 2 hook up the wires to which wire and when i do hook up the wire right their is no power going into it.
Can someone show me the procedure to do this?
Yes i am a noob in car audio
The wires coming out of the deck harness should be the exact same color as on the harness you bought, its a standard. Also most harnesses have writing on each wire to say what they are, so one wire will say like" power" and have a + or - sign on them. Its very very simple these days.
Originally Posted by gNaRKiLL
btw if you really have no idea do yourself a favor and take it to a place and have it installed, you cut the wrong wire and bam, dash lights, or heating unit go out, or worse.
Mate... If this is your first time doing an Audio install you should really let someone else handle it. But heres my advice:
1) Rip open the dash... Plenty of tutorials on that
2) The PAC ROEM-NIS2 should have 2 sets of connectors. I goes into the current Bose connector and the other into your new headunit.
3) Use the manual to connect up the appropriate wires.
4) Remember that the ground on a bose unit is the antenna & connect your aftermaket stereo's remote wire to the pink factory wire.
Hope that helps.
Hope that helps.
