Installing kenwood6019 replacing OEM BOSE?
Old Nov 22, 2006 | 08:25 AM
joegengsta's Avatar
joegengsta
Default Installing kenwood6019 replacing OEM BOSE?
i'm installing a kenwood 6019 double din into my 2004 Z which came with the BOSE system... now.. is there a harness available to match up to the factory 350z harness? i'm assuming the 350z non-BOSE unit has a differnet harness. I don't want to change my bose speakers or subs (which has their own amps). Please let me know! i dont want to buy this kenwood unit and then not be able to install it without buying a ton of other stuff.
Old Nov 22, 2006 | 08:48 AM
joegengsta's Avatar
joegengsta
i went on crutchfield and they gave me the same wiring harness for 350z that came with bose or non-bose (item 120707559) so that CAN'T be correct. i looked around some more and noticed somepeople are usng "metra" installation harnesses. does this one bypass the stock amps somehow? or supply them someway? i just dont want to install this expensive unit and have no sound or have to be forced to by peripherals or aftermarket speakers.
if the metra isntall harness works, were can i purchase this item from?
m_0g
Jun 3, 2021 10:05 AM
