Pics of XM roady installed
Old Dec 3, 2006 | 04:03 PM
FleckDZ's Avatar
FleckDZ
Default Pics of XM roady installed
I have an XM roady from my last car that i want to put in my new Z. anyone have pics to give me ideas of where to put it?
zand02max's Avatar
zand02max
Do you have Nav? If not place it in there.
Old Dec 4, 2006 | 07:04 AM
FleckDZ's Avatar
FleckDZ
i don't have the nav but i was hoping for a cleaner look than just sitting it in the cubby.
Old Dec 5, 2006 | 03:01 AM
bjr's Avatar
bjr
aw, come on! Be lazy, it's not that bad
Actually you could do like I did and make a trim bezel for it but I did not want the hassle of making it then removing it every time I want to take it in a company or rental car or pop it out to listen to it in the garage so I am very happy with mine.
I used part of the included dash vent mount that comes with it to attach it to a piece of plexiglas that I made at work to hang inside the cubby without any extra hardware. It hangs on the hidden lip above the door.
Old Dec 5, 2006 | 09:21 AM
FleckDZ's Avatar
FleckDZ
thanks for the pic. im guessing your power runs under the center console back to the power supply between the speakers. not too bad, ill consider it.
Old Dec 5, 2006 | 01:57 PM
bjr's Avatar
bjr
There is a hole in the floor of the cubby under the rubber mat. I ran the antenna, power, and line output through the hole. Be careful when you hook it up to power. The Roady and Roady2 actually use 6V and have to use the cigarette lighter plug they came with. I bought a corded cig. receptacle from Radio Shack and wired it from the fuse box under the dash and wire tied it up out of the way.
350Z_Al
Oct 29, 2020 07:44 PM
