Auido gurus: Help me wire up my amp/sub/speakers
Old Dec 15, 2006 | 01:09 PM
MustGoFastR's Avatar
MustGoFastR
Default Auido gurus: Help me wire up my amp/sub/speakers
Amp:
Kicker ZX700.5
-RMS 70 watts x 4 chan. + 210 watts x 1 chan. @ 4 ohms (or RMS 85 x 4 watts x 4 chan. + 420 watts x 1 chan. at 2 ohms)
The system it'll be driving:
Headunit:
Kenwood DDX6019
F/R speakers:
-Front: Polk/MOMO MMC6500 - 10-125 watts RMS, peak: 250 watts
-Rear: Polk/MOMO MMC650 - 10-80 watts RMS, peak: 160 watts
Sub choices:
-Sub: JL 10w1v2 - continuous power handling 150 watts RMS, peak: 400 W
single voice coil, 4 ohm (wired normally to the amp at 4 ohm load. Amp outputs 210 watts at 4 ohms to the sub)
OR
-Sub: JL 10w3v2 - Continuous power andling 300 watts, peak 600 w
dual voice coil, 4 ohm (wired as shown below to run the amp at 2 ohm load. Amp outputs 420 watts at 2 ohms to the sub)
OR
-Same JL 10w3v2 as above, but the 2 ohm version wired as shown below to run the amp at 4 ohms/210 watts.
Overall system goal:
Something that sounds a fair bt more decent than stock and actually has some bass; nothing extreme, just a fair mid-level system with good sound for what I listen to at moderate volume levels.
Ok, now the questions:
1. which sub should I go with? I listen to rock and like tight, accurate bass with decent thump when called for. I don't really pound out my music for the whole nieghborhood to hear, either. I won't be setting the sub to max. I already have a new JL 10w1v2; if that'll be fine for what I want, just let me know. I don't neccessarily have to have bigger or better just for the sake of having it; like I said, I likely won't push the system to it's max. To switch, I'd have to re-sell that sub and pick up the other one, but I can do that if it'll truly be the better all-around system.
2. If the 10w3v2, which of the two configurations above?
3. If running the mono amp at 2 ohms for the dual voice coil sub, are there any problems with the F&R amps running at 4 ohms concurrently? (I really know nothing about how amps work and ohms in this respect).
4. My headunit has a full-featured crossover and a sub pre-out. Should I use it and set the amp to pass-through or shut it off and send only the F & R signals via their pre-outs to the amp and use the amp's crossovers?
5. For the F&R speakers (each speaker has it's own external passive crossover), should I run each amp output right into a single input on the crossover and run the mids/tweeters at 4 ohms or wire it up like the dual voice coil amp diagram above and run them at 2 ohms/higher power? The crossovers can be set either way, to be single or bi-wired.
I've had alot of questions lately here regarding this sound system I'll be putting together, as performance and easthetics are more my forte, and you guys have been a great help. I'd appreciate whatever you can do for me regarding these questions, then I should be pretty much set to get it all in and sounding great!
Old Dec 17, 2006 | 10:00 AM
MustGoFastR
Anyone?
I've pretty much decided to stick with the 10w1v2 I already have for now, so questions 1-3 aren't pressing, but would still be good to know for the future.
Ignore question 5; I think I'll keep it simple.
I WOULD really like an answer to question 4, though.
Old Dec 17, 2006 | 10:45 AM
first350's Avatar
first350
so your HU's cross over's only work if you use your speaker level out?
Do your speakers have cross over units with them?
-Peter
Old Dec 17, 2006 | 01:49 PM
MustGoFastR
No, the head unit has pre-outs for all channels including sub and has a fully featured crossover/sub settings built in. I'm just asking if I should use the headunit's crossover to separate what goes to the sub or should I shut it off and use the amp's crossover?
As far as the F/R components, they have external passive crossovers to separate the mid-bass from the tweeter frequencies; that's not an issue.
350Z_Al
Oct 29, 2020 07:44 PM
bcoffee20
Nov 19, 2015 06:39 PM
nanotech
Oct 2, 2015 05:02 AM
cashmoney03
Sep 27, 2015 05:24 PM
Beater350z
Sep 9, 2015 03:36 PM
