Bose Speaker Cutting Out
Old Dec 18, 2006 | 05:55 AM
cpanagio's Avatar
cpanagio
Default Bose Speaker Cutting Out
Searched but could not find anything for this. I have an 03 Z with Bose speaker. Later my front left speaker has been cutting out (more like sounding its blown with minimal volume and lots of static). This is only happening when its in CD mode. When I turn on the radio it sounds just fine. The only logical assumption is that it could be the head unit. One night I drove over a pot hole (accidentally) and the speaker popped back in and started working. Now Im having the same problems again. Im hoping there is a fix for this because Im not in any mood to replace that head unit or put an aftermarket system in. Anyone else ever encounter this?
Old Dec 18, 2006 | 07:21 AM
RunyonAve's Avatar
RunyonAve
Go find the same pot hole?
Ok, in all seriousness, i do expierience somewhat of a static problem that sounds like the speaker is blown when i'm listening to cd. I don't have any advice to give you besides start saving up for something else cause the bose system really does suck.
Old Dec 18, 2006 | 07:28 AM
blasian's Avatar
blasian
I had the same problem once I changed my Bose HU to replace another malfunctioning one. I was going to see if I mess around with the HU and fix it but it seems like it has fixed itself.
Old Dec 18, 2006 | 07:34 AM
reptile718's Avatar
reptile718
Your head unit is broken. Search these forums, it has been discussed many times before. I had this same problem a couple of months back. Come to find out I had a refurbished Bose unit in my Z. Something about a connection coming loose inside the unit. You can always try to beat on the left side of the center console, close to the HU. Worked for a while then it would do it again but more frequently. If you are still under warranty they will replace the HU for free.
Old Dec 18, 2006 | 08:11 PM
insomniaxvi's Avatar
insomniaxvi
+1
Old Dec 19, 2006 | 04:14 AM
cpanagio's Avatar
cpanagio
The thought did cross my mind...
Thanks for the info. I gave the console a few taps like you said and it did come back in. I believe I am out of warranty so I better start warming up my fists until I decide what to do about replacing it.
sales@czp
Sep 23, 2019 03:30 PM
3vilbunny
Jul 18, 2017 05:10 PM
kyin
Oct 15, 2015 05:54 AM
Tochigi_236
Sep 27, 2015 03:40 PM
