V1 install Help!!!!!!
I need to know where and how to do the Hardwire install.
1. How do I get the wire in with the fuse?
2. where do I ground?
3. Any other tips will be greatly appreciated.
Thanks.
Pictures, lots of pictures please.
Again, thanks.
Thanks.
Again, thanks.
This install is not too difficult.
You can run the hardwire kit in through the mirror trim piece and along the roof liner then down the pillar and into the fuse panel. You need to find a wire that is 12v constant when the ignition is on around the fuse box in the driver's side kick panel. Just poke around and you will find one, but you will need an ohmmeter or DMM. If you have the service manual, you can find one easier this way.
Ground the detector to the vehicles chassis...any metal part of the chassis will work as ground for the radar detector.
Thanks for the help, but I was looking for more details. Like 1. How do I get the wire in with the fuse at the same time?
2. Where exactly did you ground your V1?
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
