Two 10"s vs One 12"
Old Jan 11, 2007 | 12:52 PM
350zspl's Avatar
350zspl
Originally Posted by dukeduster
No sorry your wrong on the superior design of the jl. Lets see a top of the line crossfire has a one way linear xmax of 2.2". whereas a w7 is only 1.15". SOOO your wrong please research your subs first thanks.
sounds like you getting huge pleasure in finding what you feel is a wrong answer
try a law enforcement career
Old Jan 11, 2007 | 12:56 PM
Fluid1's Avatar
Fluid1
Default For SPL
It's all about surface area, to move the air.
One 12: 113.04 in^2
Two 10's: 157 in^2
Old Jan 11, 2007 | 01:15 PM
350zspl's Avatar
350zspl
One 12: 113.04 in^2
Two 10's: 157 in^2
see how easy you make it
right on
Old Jan 11, 2007 | 01:49 PM
dannichols's Avatar
dannichols
right on
yep, unless your using Pi r^2 it's easy to underestimate the surface area of a slightly larger sub. 12" has 30% more surface area than a single 10"
Old Jan 11, 2007 | 03:03 PM
JimRHIT's Avatar
JimRHIT
Quick perspective gentelmen.
It is much easier to make a driver 12" driver outdisplace a pair of 10"ers
It comes down to a larger spider and a bigger/better roll for the surround. Smaller drivers are harder to control at high-excursions.
Most 12"ers have more overhang/stroke/xmax/call it what you want than their 10" counterparts.
Just because there is more Sd ... doesn't mean the 10s will be louder.
I still recommend 2 10"ers ... for the same reason as before: ease of install
Old Jan 11, 2007 | 05:44 PM
badboyblake11's Avatar
badboyblake11
Two 10&quot;s vs One 12&quot;-my-system.jpg <==== Loud as **** its just about too much when turned up all the way.
Old Jan 11, 2007 | 10:08 PM
rocks's Avatar
rocks
Well i mostly listen to rock and some drum and bass type music, and alot of industrial with fast bass. So wich 2 10s would be good for that kind of music? I dont like sloppy rap bass.
Old Jan 11, 2007 | 10:19 PM
doskiez's Avatar
doskiez
Originally Posted by badboyblake11
Attachment 130889 <==== Loud as **** its just about too much when turned up all the way.
Those are big as crap.... talk about truck hatch space youve got a ton of it with those in there lol
Old Jan 11, 2007 | 10:35 PM
dukeduster's Avatar
dukeduster
Ok yeah sorry i looked at it wrong. its one way and peak to peak. 2.2 for xfire and 2.3 for w7.
Old Jan 11, 2007 | 10:36 PM
dukeduster's Avatar
dukeduster
but wth do you need that much excursion for anyways.
Old Jan 11, 2007 | 10:39 PM
nismomonster06's Avatar
nismomonster06
i dont think the question should be 2 10's vs. the 12 you have... i think you should just go with a 13w7... beat the socks off anyone
jcrdr's Avatar
jcrdr
Originally Posted by 702Fairlady
The 10's would keep up a little better with all the beats. The 12 might give you some better low end. IMHO 2 or 3 10's in a 350Z is perfect. Im running 1 12L7 and it sounds great. But the box is so massive that it takes up my whole hatch and doesnt have muh of a show factor that an understrut fiberglass 10" box would have.
im running the kicker as well, heres my setup!
Old Jan 12, 2007 | 07:59 AM
JimRHIT's Avatar
JimRHIT
2 10" Image Dynamics IDQ sealed in small boxes.
Old Jan 12, 2007 | 05:12 PM
badboyblake11
Click image for larger version Name: z trunk!!!!.JPG Views: 3 Size: 59.0 KB ID: 130904
thats a nice set-up, one of the cleanest i have seen. props.
Old Jan 13, 2007 | 08:22 AM
jcrdr's Avatar
jcrdr
thanks a lot! my buddy hooked it up, only $500!! and its all wrapped in blk suede! next step is tv on trunk latch so when opened and tv is down, rear view cam will show people looking at it
Old Jan 18, 2007 | 07:37 AM
badboyblake11
all i listen to is rock, and those subs to the trick, its not too much, but when i go "show" and turn it up the power is there.
