After market wiring harness for bose (touring) system
Old Apr 2, 2003 | 01:41 PM
Troy9's Avatar
Troy9
Default After market wiring harness for bose (touring) system
I wanted to order the wiring harness to install my new head unit but was told that the aftermarket wiring harness is useless with the bose system (i have the touring model). Is this true? If so, which color wire is the battery, accessory, antena, ground, illumination? Any help would be greatly appreciated.
Thanks
Old Apr 2, 2003 | 02:14 PM
maserom's Avatar
maserom
Good question!
Old Apr 7, 2003 | 04:28 PM
Troy9's Avatar
Troy9
anyone?
Old Apr 8, 2003 | 05:25 AM
srobert910's Avatar
srobert910
the standard metra wiring harness worked with my bose system. Plugged right in, and for now i'm using the factory amps and speakers and it sounds quite a bit better. Just make sure that you hook up the amp turn on lead if you're going to be using the factory amps.
sales@czp
Sep 23, 2019 03:30 PM
nanotech
Oct 2, 2015 05:02 AM
