KP Technology Window Roll Up
Old Feb 4, 2007 | 07:10 PM
IzYou's Avatar
IzYou
Exclamation KP Technology Window Roll Up
I received the Window Roll up module on friday. I've been trying to install it this pass weekend but have had no luck. Im having a hard time and wanted to get confirmation that I am installing the unit correctly.
My car is an 05 Touring with bose/non-navigation .
This is the harness I am tapping into. It is the driver side window control.
First attempt I wired the items as follows. (no pics)
Kp tech module to Window control harness
Red - 12v - white
Black- Ground - black
Yellow- Ignition - tried (Blue)
tried lighter (baby Blue)
Green- Lock cylinder - Red
Purple- Lock actuator - Purple
that didn't work.
My 2nd attempt. (with pics)
12vdc - White
Ground - Black
RAP - Brown
Door Lock Cylinder - Black/Red
Door lock actuator - Purple (behind speaker)
I used the post from https://my350z.com/forum/showthread....window+roll+up where KPierson stated the 05 wiring changes. It still didn't work.
Here is a picture of the rest of the wires. For reference.
Can someone let me know the wiring colors (car side) to tap for the following connections?
12 volts, Ground, ignition, lock cylinder, lock actuator.
I just want to confirm the right colors and see if maybe I'm just getting a bad connection.
I've researched alot and have spent an ample amount of time trying to figure this out.
your help is appreciated.
Old Feb 4, 2007 | 11:41 PM
IzYou's Avatar
IzYou
Default found the answer. just have to check so now its a DIY
Didnt realize there was a forum for kptechnologies products.
Correct Wiring Information:
KPtechnologies 350Z (05 Touring)
12 Volts (RED) - White (located in the window control harness use thick one)
Ground (BLACK) - Black (located in the window control harness use thick one)
Ignition (YELLOW) - Sky Blue (located in the window control harness use thick one)
Lock Cylinder (GREEN)- Red (located in the window control harness use thick one)
Lock Actuator (BLUE) - Purple (located behind the driverside speaker small wire loom containing 4-5 wires)
Link to removing door panels.
http://liljerk.morpheus.net/350Z/front_speakers/
Kp technology forum.
http://kptechnologies.com/forums/viewtopic.php?t=38
Tips : Just take your time and don't rush. Plan out your steps before you execute them.
Old Feb 5, 2007 | 02:16 AM
KPierson's Avatar
KPierson
It sounds like you got it working!
Over the years we've made the modules pretty much indestructable when it comes to wiring them up wrong, but we have nothing to do the electronics in the car. I caution anyone from hooking up wires without verifying them with a volt meter first.
According to the service manual the RAP is the brown wire on the '05, so you may have that connection wrong. However, there is only one sky blue wire listed in the manual, so maybe your car is different then the manual states (very possible).
Either way, the yellow wire isn't really needed on this module. It's a safety wire that is redundent to the OEM safety feature that prevents the windows from going up if the car is on.
Let me know if you have any other questions,
Old Sep 5, 2013 | 03:41 PM
blackznismo's Avatar
blackznismo
2007 the purple wire behind the speaker is NON existent, please help.
Old Sep 7, 2013 | 03:21 PM
blackznismo
got it done, thanks
Old Sep 8, 2013 | 02:44 PM
KPierson_'s Avatar
KPierson_
Where did you end up finding it?
Obadabot
Jun 18, 2023 11:31 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
