speaker swap?
is it possible to replace only the head unit, or only the speakers, or is this crappy bose system the same as in the z32's where the head unit, speakers, and wiring were all uniquely bose and not compatible with any aftermarket components?
I am pretty sure that everything must be changed. That was the case with my Acura Cl as well. It had a Bose system. The set up was a little different than the Z. To be honest I really liked the Set up in the Acura, but those are the breaks....
Originally posted by maserom
Fronts are infiniti kappas 63.5 3 way
Rear infiniti kappa 2 way in the rear.
Sound great! Look on Ebay
Also, I'm assuming you disconnected the factory tweeter's up front by the windows?
The only reason I put the 3 ways up front is b/c everyone else, stereo nerds are saying that is what to do so you get the highs up front. You can even put one ways in the rear. I did disconnect the tweeters up front, however i may upgrade later. Put the 3ways up front you'll be glad.
I'll have to do more research.
Thanks.
I dont' know the specifics on the speakers. Like I said, I'm just listnign to what everyone else, more knowledgable stereo people are doing. I did the speakers myself. It is fairly easy. There is a post on front speaker installing. It is very helpful. I'll email it you if you can't find it.
