v1 mount - HELP!
Old Feb 17, 2007 | 11:23 AM
Cannysage's Avatar
Cannysage
Default v1 mount - HELP!
I got the mike mount and the invisicord and still not getting any power!!
black ground and tried both pink/blk and red/blk for power and still notihing!! wtf?
Old Feb 17, 2007 | 11:58 AM
Mike Wazowski's Avatar
Mike Wazowski
PM acree, he should be able to help you
Old Feb 17, 2007 | 05:07 PM
Cannysage's Avatar
Cannysage
I think I'm just gonna do it the long way.. thanks though.
Old Feb 17, 2007 | 06:59 PM
mthreat's Avatar
mthreat
Is your mirror getting power? Are you turning the ignition on? (Dumb questions I know, but I always start with the simple stuff)
If your mirror is getting power, then the problem has to be somewhere in the invisicord itself, or in the connection between the invisicord and the mirror power plug.
-chris
Old Feb 17, 2007 | 11:58 PM
Cannysage's Avatar
Cannysage
dunno.. it looks so simple.. just plug the invisicord right below the hot wire and the other one below the ground, right?
ignition was on and mirror definitely gets power.
Old Feb 19, 2007 | 01:04 AM
mthreat's Avatar
mthreat
Yea.. make sure the invisicord pin is making contact with the wire inside the power plug (metal). Here's a photo, you can't see the metal-to-metal contact here, but you can see how far in I stuck the pins.
Old Feb 19, 2007 | 01:31 PM
OffsetZ33's Avatar
OffsetZ33
Where do you get the radar mount? what does it look like? Thanks!
Old Feb 19, 2007 | 05:03 PM
wahooj's Avatar
wahooj
I had a tiny bit of difficulty connecting my invisicord. One of the pins didn't want to go in. Still only took ~ 10 minutes to get working.
Old Feb 19, 2007 | 05:11 PM
Bob Martin's Avatar
Bob Martin
I had the same problem and found out later that I didnt order a little pieace that lets it work with the 350z mirror. Are you sure you order the right parts?
Old Feb 21, 2007 | 12:17 AM
Cannysage's Avatar
Cannysage
thanks for the input fellas!!!! got some pliers (howerever you spell it) and shove the wire in with moderate force. It's so clean!!
Old Mar 30, 2007 | 06:15 PM
MarkY's Avatar
MarkY
I ordered that little piece and the only thing in the bag was the visicord. Is the piece already attached via shrink tubing?
Old Mar 31, 2007 | 09:47 PM
wahooj's Avatar
wahooj
There is no extra piece. Its just a different size pin on the end. You have to click on it as an option when you order.
Old Mar 31, 2007 | 10:51 PM
MarkY's Avatar
MarkY
I got it working. The pins just needed a little extra shove. It's a tight fit.
HoBrahYouStink
Jun 24, 2016 10:58 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
