Cap problems
on
Cap problems
well, my battery was dying a couple months ago and it turned out to be my capacitor that was draining my battery. so i purchased a brand new capacitor (same model) and guess what, the car battery died on me again. now, the first time i was having this problem, i changed the car battery so it is brand new. what could be a solution to my cap problems? bad wiring? thanks guys.
on
https://my350z.com/forum/audio-and-video/230754-constant-battery-draw-help.html
why don't you check the other thread you have going with 40 replies rather than starting a new one.
On a real note, if you can draw up a schematic of how everything is wired I would be happy to answer, but without that drawing I can't help you. I'm 99% certain that your problem is you are either wired wrong or your cap is bad, which should sound familiar from your other thread. If I know how your system is wired then I can tell you if you have a wiring problem and if there is no problem in the hook up then you likely have a bad cap.
08-06-2021 06:19 AM
