box size recommendations? for 2 10" orions
Old Mar 27, 2007 | 11:05 AM
cvkatigbak's Avatar
cvkatigbak
Default box size recommendations? for 2 10" orions
ORION HP SERIES SUBWOOFERS
Who let the dawgs out? Orion High Performance (HP™) that’s who! HP takes raw power to a whole new level, with machine-turned die-cast aluminum baskets and powerful Open Loop motors that utilize a vented hybrid magnet structure which dramatically increases airflow through the speaker.Open Loop speaker technology keeps the HP-Series subwoofers running cool even under the most demanding SPL situations.
Features:
* Power Handling 500 Watts RMS / 1000 Watts Peak
* Machined Custom Die-Cast Basket
* Open Loop Motor Design
* Metalized Poly Cone and Medium Roll NBR Surround
* Tight Small Sealed Box Performance
* Custom Tooled Reversible Wrap Gasket and Protective Magnet Boot
* Heavy Gauge Wire Terminals
* 2.5 Inch Voice Coil on Aluminum Former
dual 2 ohm
ORION HP 10D2
10 inch
500 Watts RMS/1000 Watts Peak
5.25" Mounting Depth
dual 4 ohm
ORION HP 10D4
10 inch
5.25" Mounting
do you guys know what size box i should put, i have two 10" i dont know if theyr 4 or 2 ohm. like what specs of full box? thanks.
Old Mar 27, 2007 | 11:10 AM
350zspl's Avatar
350zspl
Features:
dual 2 ohm
ORION HP 10D2
10 inch
dual 4 ohm
ORION HP 10D4
10 inch
5.25" Mounting
sounds like you copy pasted the web site
i am sure if you go to their web site they can make recomendations on box size
500 rms is average
though they say it is a beast
good luck with equipment
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
