Alpine TME-m760--how to bypass parking break security?
Old Apr 13, 2003 | 02:30 PM
MSGarrett1's Avatar
MSGarrett1
Default Alpine TME-m760--how to bypass parking break security?
Hey, Anyone2u or any of the many other Alpine TME-m760 screen owners . . . . how did your installer bypass the parking break security with this screen?
Old Apr 13, 2003 | 02:43 PM
Itzted350z's Avatar
Itzted350z
theres a wire that comes with the unit, you just install that and it should bypass it...they give you directions with the wire...
Old Apr 13, 2003 | 03:11 PM
qirex's Avatar
qirex
hmmmI had mine installed months ago....
Do I need a new wire?
I heard that you can simply send the wire to the brake to ground instead.
Old Apr 13, 2003 | 03:45 PM
Encore's Avatar
Encore
The parking break wire can be hooked to ground. The Alpines that you have to hit the foot brake you can hook the Alpines park brake wire to a switch hooked to ground, and hook the foot brake wire up normal. Press the foot brake, then hit your switch on off on, and the screen will stay on until the car is cut off or until you hit the switch off.
Old Apr 13, 2003 | 05:44 PM
neo's Avatar
neo
Default Ground
My poineer just needed and "ground". Supposed to be on the parking brake, but it does not know the difference...
Parking brake "up", ground is closed, screen works.
Parking brake "down", ground is open, screen no workie...
Always grounded, ground is closed, screen always works.
Cheers
Old Apr 13, 2003 | 06:12 PM
Encore's Avatar
Encore
Most Alpines are a little harder than that. They hook to the foot brake, and park brake to make it a little harder to get around. I think perifal actually makes a piece were you dont have to go through the trouble w/ a switch, and all, but its just as easy to do it the way I said.
Old Apr 14, 2003 | 04:34 AM
MSGarrett1's Avatar
MSGarrett1
Default Re: Ground
Cheers
Yeah, this is how it works with the Pioneer, Kenwood, and many other screens, but not with this Alpine one, it seems.
Pleask
Dec 21, 2021 03:17 PM
ablaine
Nov 29, 2016 10:13 AM
dcains
Nov 11, 2015 11:36 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
