Sound Blocking Materials
Old Apr 11, 2007 | 12:48 PM
HARRYPOTTER's Avatar
HARRYPOTTER
hmmm...ok...ic...wel I think my box is slightly over...recommended enclosure is .6, and I have .7.....will this *** me up?
Old Apr 11, 2007 | 03:12 PM
alexlindeman's Avatar
alexlindeman
It will not mess up anything, but it just isnt needed.
With a larger box comes lower power handling, and boomier sound.
Old Apr 12, 2007 | 05:03 AM
HARRYPOTTER
hmmmm...so what your saying is....I blew it...
well what I can do is keep adding layers on the inside of the box until I got the correct space...this is ok right?
Old Apr 12, 2007 | 06:26 AM
alexlindeman
you can add more wood to the box to reduce the volume, but it shouldnt be needed.
Old Apr 12, 2007 | 06:46 AM
HARRYPOTTER
wood?....the entire thing is fiberglass...I can't add wood, but I know what you mean...
Old Apr 12, 2007 | 11:48 AM
LAKERSFAN's Avatar
LAKERSFAN
how much of each in sq ft would you recommend getting?
Edead v1se
Edead V.4
And is the v3 stuff just glue? how much of this would you recommend getting.
Planning to do the floors and hatch.
thanks!
Old Apr 12, 2007 | 11:53 AM
HARRYPOTTER
floors and hatch?...hmmm I think you should also consider the doors...but just floors and hatch all you need I would say 4-5 yards... but i'm not too sure about how they have their stuff cut...you might have to ask someone who has used it before, because I used the Raamat.
Old Apr 12, 2007 | 01:44 PM
LAKERSFAN's Avatar
LAKERSFAN
Actually have the doors dynamatted already. Thats why i was thinking just doing the floor and hatch for now. See how it turns out then if i think the doors need a little more, than go from there.
OH, and how many sq. ft. is in a yard.....
Old Apr 13, 2007 | 05:03 AM
HARRYPOTTER
well wouldn't it have to be sq. yards?....
but anyway...if you buy the Raamat...you will have enough to do the entire car... as far as the ensolite 4 yards is enough fro your application.
Old Apr 13, 2007 | 08:50 AM
LAKERSFAN's Avatar
LAKERSFAN
Any good DIY threads on taking everything apart, etc? I searched through several pages but didnt see anything.
Saw the sticky thread at the top but none of the links seem to work.
Old Apr 13, 2007 | 09:02 AM
HARRYPOTTER
it's Japanese....just tug anywhere, and something is bound to give....lol
Old Apr 13, 2007 | 09:34 AM
Hokie2000's Avatar
Hokie2000
If this is what you're looking for.... Here's the instructions for removing the door panel:
http://liljerk.morpheus.net/350Z/front_speakers/
Old Apr 13, 2007 | 10:05 AM
LAKERSFAN's Avatar
LAKERSFAN
lol
Old Apr 13, 2007 | 10:27 AM
LAKERSFAN's Avatar
LAKERSFAN
This is perfect. thank you.
anything you know of for taking the floor and hatch apart?
Old Apr 13, 2007 | 10:43 AM
HARRYPOTTER
it's all generally the same...if you do the doors...you can def. do everything else...good luck
Old Apr 13, 2007 | 11:01 AM
Hokie2000's Avatar
Hokie2000
There's a link on another 350Z forum to download the service manual for your car. It should have the diagram somewhere in there for removal of the carpet.
Old Aug 7, 2007 | 05:43 AM
BabyZiLLa's Avatar
BabyZiLLa
On this note.. Anyone got tips for applying the sticky first layer of deadening? I've never done it yet but it kind of sounds like its so sticky that once it touches something its down. How do you get it equally spread?
Old Aug 8, 2007 | 09:23 AM
  #38
HARRYPOTTER
just cut a good size piece and put it in place...just like a puzzle...it's really simple...just don't cut too big a piece because then it might not go down too easy.
Old Nov 14, 2007 | 07:20 AM
  #39
Ge|atinousFury's Avatar
Ge|atinousFury
Has anyone ever used the Edead v4 closed cell foam over Raamat BXT?
Just want to know if the Edead will stick as good or not since they're made by 2 different companies...
If everything will be OK then I will be applying Edead v4 over the Raamat on my doors.
Old Nov 14, 2007 | 07:55 AM
  #40
350zspl's Avatar
350zspl
i use stinger expert road kill peel roll and seal
works well
can be doubled or even tripled
