Sound Blocking Materials
Old Apr 3, 2007 | 06:19 AM
HARRYPOTTER's Avatar
HARRYPOTTER
Default Sound Blocking Materials
I've been Debating whether or not to use Raamat (sound dampening material) on my car for a while, and I finally just decided to do it, because it would only add an extra 25 pounds to my vehicle. With that said I just went outside and started to install the material.
I used an Exacto knife for the install, because it allowed me to get the cuts perfectly. This stuff (butyl based) is super sticky, and can get messy at times just like dynamat, but it痴 lighter, and bonds better IMO. Here are some pictures of the final product after attaching the Ensolite (closed cell foam) over the Raamat. It was super easy, and I used camie 313 upholstery spray glue to get the job done. It痴 very simple, but just requires a lot of patience. As you can see I took care in getting this door to be near perfect.
I also decided to add some Raamat to my actual fiberglass sub box (still building it) in hopes that it will stop any rattling (if there is any) of the fiberglass itself. (I値l post pics of that later, because I知 still not finished doing the box.
I知 eager to see how the system will sound since I知 basically building everything myself. I値l keep you all posted as I move along.
Attached Thumbnails Sound Blocking Materials-0330071817.jpg   Sound Blocking Materials-0330071817b.jpg   Sound Blocking Materials-0330071818.jpg
Old Apr 3, 2007 | 06:21 AM
HARRYPOTTER
in the second picture you can see the perfect seal that the raamat and Ensolite make when attached to the door. It was great to see everything finally come together....the next step is to do the floor panels, and then upholster the entire interior.
Old Apr 3, 2007 | 06:41 AM
rotaryrocket7's Avatar
rotaryrocket7
I just finished a complete tear-out and sound reduction job on the Z.
I used a method simialar to DanniNichols, and a few others on the board.
First, a layer (or more) of Raammat over most of the floor and cubby areas, also the rear and both doors.
Then a layer of open cell foam (3/8's inch) over the floor, two layers in the cubby area, and a layer in the rear. The doors did not get this as it is moisture sensitive (can mold).
Over all of that a layer of ensolite on the floors, cubby and rear. I used two layers of ensolite in the doors.
The results are unbelievable. It is actually quiter than my GF's brand new Honda Accord. I can talk on the cell phone easily at highway speeds, including on concrete roads with grooves.
I would recommend that you seriously consider the open cell foam on the floors and cubby as that will do the best job at reducing noise whiel the ensolite does a great job at blocking...
Old Apr 3, 2007 | 06:52 AM
HARRYPOTTER
thanks...i'll do that...where can I buy some?...by the yard
Old Apr 3, 2007 | 07:21 AM
rotaryrocket7
I bought carpet underlayment pad, which is foam ( basically the stuff you put underneath carpet at home). You can also get fiberous material intended for automobiles (I'm sure you've seen this grey with different colored fibers). The fiberous material can be picked up on-line through auto restoration sites, and the carpet underlayment I bought at Menards (Like a Home Depot, Lowes).
I used about 11 sq yards of it.
Two things to consider: The cost of the foam type is much less (I spent about $35 on it), compared to at least double that for auto specific.
The auto specific is much easier to work with, it bends folds etc... where the foam is more ridgid. Also, the foam is susceptible to moisture issues, since I used Ensolite over it, and sealed the edges with Duct tape, I'm not concerned about the moisture, but be mindful if you take your car out in the winter... Also, don't use it in the doors (looks like you already finished them anyway)
I saw you glued the ensolite down, I actually opted to duct tape that as well in case I ever needed to get it out (for example over the fuel pump in the cubby etc...)
Good luck, and once you're finished report back on your expectations and whether or not they were met.
Old Apr 3, 2007 | 07:34 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
i like raamat sound dampening a lot, but i am not a fan of their ensolite, too muh of a pain to do, i prefer using edead V4, whcih is in itself a stickybacked foam thicker thant he ensolite...much easier to install
but cudos for your patiences, it looks great!
Old Apr 3, 2007 | 08:01 AM
HARRYPOTTER
thanks...ummm is the e dead pretty expensive?...because it sounds like it's easier to apply, and I want to use something that's fairly easy for the floor...I'm almost done with the Raamat anyway...I just don't know what to do with the floors that's all..it seems as if this would be where alot of road noise is coming from.
and to seal some of the edges...using aluminum foil taip is the best, but it's super expensive....that's what I use on some corners...
Old Apr 3, 2007 | 08:07 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
its chepaer than raammat on the sound deadening part, not sure on the ensolite thing, but it is MUCh thicker than ensolite
www.edesignaudio.com edead v.4 is the name
b
Old Apr 3, 2007 | 08:15 AM
HARRYPOTTER
sounds good...i'll give it a go for the floor panels...I don't need mch anyway...so it's ok.
Old Apr 4, 2007 | 10:51 AM
Hokie2000's Avatar
Hokie2000
b
Not to hi-jack this thread... But I'm the process of ordering the edead material for my doors and was wondering if the adding the edead v.4 (Teklite) on top of the edead V1SE would make a considerable difference in dampening the noise from the doors?
I'm guessing this process is similar to what the original poster did. I was just curious if adding a second layer of the foam material was worth it?
Old Apr 4, 2007 | 11:18 AM
HARRYPOTTER
I think it is...it makes everything so quiet...
I can't wait to do the floor panels...
Old Apr 11, 2007 | 07:05 AM
HARRYPOTTER
hey rotary rocket7...where where you able to purchase that cheap carpet undelayer mat?...
Old Apr 11, 2007 | 08:15 AM
alexlindeman's Avatar
alexlindeman
The SE is a mass loader, it reduces rattle and vibrations.
Mass loaders typically work from 250hz and down.
The v4 is 1/4" closed cell adhesive backed and acts like an acoustic sponge, it absorbs higher frequencies, from 250hz and up.
No advantage of doubling up the v4, the law of diminishing return kicks in after 1/4"
Old Apr 11, 2007 | 08:26 AM
HARRYPOTTER
really?........
Old Apr 11, 2007 | 08:27 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
guys, alex is from Elemental designs, so take his word as facts
b
Old Apr 11, 2007 | 10:17 AM
Chugg's Avatar
Chugg
also not to hijack, but, if i were putting all new stereo stuff in the car already would it be a good idea to sound dampen the whole car? or the doors or just the sub box? how much does it normally cost, big question is - is it really worth it?
Old Apr 11, 2007 | 10:25 AM
Sean's Avatar
Sean
I just got this, it tested better than all others, I will put it in when the weather looks like it will be nice for 2 days in a row.
Damplifier ProT Shop Pack 279.36
Old Apr 11, 2007 | 11:14 AM
Hokie2000's Avatar
Hokie2000
Hey thanks for the info. I had already ordered and received the VSE and I ordered the Teklite (V4). So it sounds like I can benefit from adding 1 layer of the VSE and put 1 layer of the V4 on top of that. Does this sound right? I was planning on doing my doors this weekend.
Old Apr 11, 2007 | 11:30 AM
HARRYPOTTER
sounds right to me...Maybe 16 PSI and Alex can chime in...they have been guiding me through everything.
but I wanted to ask you guys why people put polyfill or whatever that $hit is inside speakerboxes. What exactly does it do, and can i benefit from it?
Old Apr 11, 2007 | 12:43 PM
alexlindeman
To answer the first question.
That is correct.
1-2 layers of SE and then 1 layer of V4.
As for polyfil.
Some people use it to kill standing waves in an enclosure. Others use it when the enclosure volume is a little on the small side.
It makes the enclosure appear larger than it actually is.
Alex
