Kenwood Excelon Amps Blowout Kac-x812d & Kac-x522
Old Apr 12, 2007 | 07:37 AM
Nazar's Avatar
Nazar
Default Kenwood Excelon Amps Blowout Kac-x812d & Kac-x522
These amps are perfect for you 350Z Guys, I have 2 channel and sub amos. Since most of you are skipping the rear speakers or running them off deck power this is a great deal.
My recommendation is get the 2 channel for fronts speakers and maybe upgrade the speakers.
And get the sub amp for a nice upgraded Sub box. Hopefully a Wicked CAS Magic box. Triple 10" or single 10w7 Box.
I ONLY HAVE 3 OF EACH AMP IN STOCK.
KAC-X522 $109 Shipped. REAL POWER 125 WATTS X 2 Plenty of power.
High Performance 2-channel Power Amplifier
2 x 165 Watts RMS @ 4 ohms CEA-2006 rating
2 x 254 Watts RMS @ 2 ohms CEA-2006 rating
0.5% THD @ rated output
Mosfet power supply
Variable low pass/High pass filter 50hz-200hz 12/24 db per octave
infrasonic filter @ 15 or 35 hz 24 db per octave
Adjustable frequency bass boost circuit
Adjustable treble frequency control
Bass Q factor control
Bass level control
Variable band reject filter
A.M.S. (Amplifier Management System)
Built in Parametric EQ Control
AMP Information Display (Voltage, Current, Temperature, Cooling Fan Speed)
Built-in Variable Low-pass/High-pass Filter
Built-in Infrasonic Filter
Gold Plated Input/Output Terminals
Line Output Terminals (RCA) for Extension
2-Speed Cooling Fan
Detachable Aluminum Dress Plate
Die cast aluminum heat sink
Toroid noise suppression
Copper EE core power transformer
KAC-X812D $129 Shipped GOOD FOR REAL 500 WATTS OF POWER.
Kenwood Excelon represents great amps.
These amps use Kenwoods A.M.S Amplifier management. This allows for parametric EQ, Voltage, current, temperature, and fan speed display!
These amps have variable speed cooling fan to keep them operating at maximum efficiency
RMS Power533Watts Power at 2 Ohms919Watts Fan CooledYes Channel Operation1 LED Power IndicatorYes Input/OutputKenwood Excelon KAC-X812D Fuse Rating30 x 2Amp Input Voltage14.4Volts Low-Pass Crossover Frequency50-200Hz Low-Pass Slope24dB Preamp Outputs1 pair
BUY A 2 CHANNEL AND a SUB AMP $220 SHIPPED.
THANK YOU FOR LOOKING
Old Apr 23, 2007 | 07:55 AM
Nazar's Avatar
Nazar
Sold Out.
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
dcains
Nov 11, 2015 11:36 PM
kyin
Oct 15, 2015 05:54 AM
Shane86
Sep 17, 2015 05:33 PM
