Drivers seat sub
What was the problem with the JL? I know the bracket is made for a 10 sub. Being honest, I have never used any JL equipment,,,,but from what I understand and experienced,,,the bracket is made for a 10 sub.
Also,,,,I am not sure what kind of sound you are looking for,,,but a sub mounted to the factory bracket (free-air) is not going to give you much.
If you are set on using that location for your sub,,,I would check out WickedCAS (NAZAR),,here on the site....His company makes custom fiberglass enclosures for that space and the pass side glove box area.
I hope this helps,,,,,keep us informed on your installation,,,,post pics during the process.
You should be able to fit any 10" sub in there. To mount it you will either need to make a bracket that mounts to the factory holes or you can do like I did and just mount the sub right on the bracket with screws.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
