Stock Head Unit Color Code?
Old Apr 22, 2003 | 04:42 AM
alphared's Avatar
alphared
Default Stock Head Unit Color Code?
I'm keeping my stock head unit, but upgrading all the speakers. Question is, I have a line to RCA converter. Which wires do I patch into to get the Head unit speaker R and L out? And do I use the Head unit ground also or just ground it to the body?
Old Apr 22, 2003 | 06:03 PM
Qbnmissile's Avatar
Qbnmissile
If I remember correctly, you can still use the ground from the HU. As far as signal, you can use the front R and L to hook up to your line-RCA converter. In all actuality, it makes no difference whether you use the front or rear R/L for signal acquisition. It's all the same once it passess through the line-RCA converter.
Old Apr 22, 2003 | 06:22 PM
alphared's Avatar
alphared
I've found the wires in the service manual. Question now is do I need 2 line to RCA converters? Fronts and rears are seperate lines.
dcains
Nov 11, 2015 11:36 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
kyin
Oct 15, 2015 05:54 AM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
