Wiring power/heated seats to a base model
Old May 7, 2007 | 07:15 AM
labelworkshop75's Avatar
labelworkshop75
Default Wiring power/heated seats to a base model
Hey, I just got some power/heated seats for my 06 base Z and I was wondering what has to be done to install them. The base model doesnt come with the correct wiring for power/heated seats since this was not an option in the base. Just trying to figure out what needed to be done for my seats to move!!
Old May 7, 2007 | 06:23 PM
sixsigmalarry's Avatar
sixsigmalarry
Thumbs up Not sure, but this is sometimes true on other cars...
Check under the seats for a slit in the carpet for a wiring harness or a wiring harness connector. You might be in luck!
If not, I'd suggest getting a service manual (I don't have one or I would tell you) and see what pin's do what on the wiring harness on your seats. From there you can power up your seats.
GOOD LUCK!
Old May 7, 2007 | 09:13 PM
drumminguy81's Avatar
drumminguy81
i put some in my car. there is a 4 pin harness on the seat for movement you one use 2 of the wires, 1 power and 1 ground.. though i dont remember what colors.. all you will have to do is run a power and ground to each seat and you will have movement.. as far as the heaters go im not sure yet, i purchased the switches but have not gotten around to figuring out the wireing for them yet..
350Z_Al
Oct 29, 2020 07:44 PM
350z82
Oct 1, 2015 06:25 PM
