Radio not working on my new system
Old May 17, 2007 | 12:47 AM
doreamon50's Avatar
doreamon50
Default Radio not working on my new system
I finished installing my sound system this past sunday. Everything seems to run good until I start to listening to radio station. I was about to hear sound coming out of my speaker from the radio station for about 3-5 minutes, and all of sudden it goes out, I got no sound coming out of the speakers. I do feel a slight bass from my woofer, but no sound. So I changed it back to CD mode, and it plays fine, when I switch it back to radio no sound. So I restart my deck and I was able to go hear the radio again, but this time about 30 second it did the same thing. Does anyone know what the problem is??
Old May 17, 2007 | 01:43 AM
k0ukim0nst3r's Avatar
k0ukim0nst3r
Could be the receiver. Might be defective. Or you can check you radio signal input and make sure it's secured in the receiver.
Old May 17, 2007 | 08:35 AM
doreamon50's Avatar
doreamon50
I had this deck for about 2 months, radio were fine the these 2 months, but after I finished install my 2nd Amp and Woofer, this started to happen. I'll double check to see the radio signal.
Old May 17, 2007 | 08:36 AM
doreamon50's Avatar
doreamon50
I had this deck for about 2 months, radio were fine these 2 months, but after I finished install my 2nd Amp and Woofer, this started to happen. I'll double check to see the radio signal
Old May 17, 2007 | 05:43 PM
doreamon50's Avatar
doreamon50
just check my antena connection on the back of my deck and found out it was okay. Could it actually be the amp's problem? but if the amp does go in to portection mode, it won't play music when I switch back to CD mode.
On my amp there's a gain control and Hz control, how should I set these 2 control to? (new to sterao system)
Justin100
Nov 29, 2015 03:58 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
nanotech
Oct 2, 2015 05:02 AM
