Factory alarm...won't activate
Old May 24, 2007 | 11:48 PM
SILKZ03's Avatar
SILKZ03
Default Factory alarm...won't activate
Has anybody had a problem with the factory alarm? Mine won't activate. The remote locks the doors but alarm won't activate....could be a fuse, other problems? or go dealer or quickfix? any answers?
Old May 25, 2007 | 12:09 AM
JDMFairladyZ33's Avatar
JDMFairladyZ33
Does your lights flash when you hit the keyfob to lock?
Old May 25, 2007 | 06:50 AM
usmanasif's Avatar
usmanasif
What do you mean it "won't activate". It doesn't go off if you leave the windows down, lock the car with the fob, wait a few seconds, reach in and unlock either door by hand and open it with the handle?
Old May 25, 2007 | 07:33 AM
mdracer76's Avatar
mdracer76
make sure your trunk , doors, and hood are all closed properly
Old May 25, 2007 | 07:35 AM
CRIDDA's Avatar
CRIDDA
If it just does not beep, I believe you have to hold the lock and unlock buttons together and that should activate your horn. That might be your problem.
Old May 25, 2007 | 08:05 AM
cheshirecat79's Avatar
cheshirecat79
Ditto on the beep- if it's turned off the doors will lock and the lights will not flash (at least on my 06) but the alarm is still armed. Just looks different.
Rob
Old May 25, 2007 | 08:36 AM
DavesZ#3's Avatar
DavesZ#3
Roll down your window then lock the car with the key fob. Wait 60 seconds then reach in and unlock the door and open it. If the alarm goes off, you're good; if not, then you have a problem.
Old May 25, 2007 | 09:18 AM
SILKZ03's Avatar
SILKZ03
the signal lights flash and the horn goes off, doors lock but the main lights don't and the when windows rolled down and unlocked, nothing happens.
Old May 25, 2007 | 04:01 PM
Chad68's Avatar
Chad68
Doesn't the factory alarm go off from a voltage drop?
What if his dome lights are switched to the always off position? Wouldn't that prevent the alarm from going off?
I had the car for a few weeks before I realized the Z didn't have an alarm as standard equipment. LOL
Old May 25, 2007 | 04:06 PM
saberphx's Avatar
saberphx
Alarm isn't standard?? Didn't know that, my base has alarm
Old May 25, 2007 | 04:33 PM
DavesZ#3's Avatar
DavesZ#3
Yes, the alarm is standard on all Zs.
Chad68 - no the alarm isn't triggered by a voltage drop and I don't see what the interior light would have to do with the alarm system anyway.
This is the explanation from Chapter 2 of your owners manual. (That thing that everybody gets but nobody reads.)
VEHICLE SECURITY SYSTEM
The vehicle security system provides visual and
audio alarm signals if parts of the vehicle are
disturbed.
Security indicator light
This light blinks whenever the ignition switch is in
the LOCK, OFF or ACC position. This is normal.
How to arm the vehicle security
system
1. Close all windows.
The system can be activated even if the
windows are open.
2. Remove the key from the ignition switch.
3. Close and lock all doors, hood and rear
hatch/trunk lid.
Lock all doors by pressing the LOCK button
on the keyfob. When using the keyfob, the
hazard indicators flash twice to indicate all
doors are locked.
4. Confirm that the security indicator light
comes on. The security indicator light glows
for about 30 seconds and then blinks. The
system is now activated. If, during this 30
second time period, the door is unlocked by
the key or the keyfob, or the ignition key is
turned to ACC or ON, the system will not
activate.
Even when the driver and/or passengers
are in the vehicle, the system will activate
with all doors, hood and rear hatch/trunk
lid locked and ignition key off. Turn the
ignition key to ACC to turn the system off.
Vehicle security system activation
The security system will give the following alarm:
 The headlights blink and the horn sounds
intermittently.
 The alarm automatically turns off after approximately
50 seconds. However, the alarm
reactivates if the vehicle is tampered with
again. The alarm can be shut off by unlocking
a door with the key, or by pressing the
UNLOCK button on the keyfob.
The alarm is activated by:
 Opening the door without using the key or
keyfob.
 Opening the rear hatch or the trunk lid without
using the release switch or keyfob.
 Opening the hood.
How to stop an activated alarm
The alarm will stop only by unlocking a door with
the key, or by pressing the UNLOCK button on
keyfob. The alarm will not stop if the ignition
switch is turned to ACC or ON.
If the system does not operate as described
above, have it checked by your
NISSAN dealer.
Old May 25, 2007 | 04:40 PM
NissanZfan's Avatar
NissanZfan
That’s the way to find out...end of discussion.
Old May 25, 2007 | 09:33 PM
SILKZ03's Avatar
SILKZ03
Did it done that.....thats why I made an appointment at the dealership 4 June 07. Read the manual was my first step, had my Z since 2003, loaded touring model. JUST THOUGHT I WOULD PUT IT ON THE FORUM TO SEE IF I WAS MISSIN SOMETHING AND WOULDN'T HAVE TO GO TO THE DEALER....GUESS NOT....SEEMS LIKE ALL THE DISCUSSION LEADS BACK TO THE MANUAL AND DEALERSHIP. THANKS ANYWAY GUYS FOR ALL THE HELP!!
Old May 25, 2007 | 09:38 PM
SILKZ03's Avatar
SILKZ03
ONE MORE THING...THE ONLY THING I HAVE DONE WAS GET A NEW SEBION HOOD...IT CLOSES PROPERLY...SO THAT COULDN'T BE THE PROBLEM...IM JUST GOING TO THE DEALER...FREAK IT!!
Old May 26, 2007 | 01:36 AM
Chad68's Avatar
Chad68
Well I locked it before with the windows down and opened it from the inside and nothing happend. Maybe I didn't wait 60 seconds.
I'm gonna go try again.
Old May 26, 2007 | 01:54 AM
Chad68's Avatar
Chad68
Wow you will never guess what I just found out what my Z has
Before when I tested it, I must have not waited 60 seconds.
Swear to God I couldn't find the alarm info listed in my manual. Found the section on how to change the key fob settings for the keyless entry but nothing on the alarm.
Could never understand why the panic button worked but that they didn't bother to make the alarm functional. I was like damn how much would it have cost Nissan to just have the damn alarm functional as standard equipment.
Ummm now I know why
sales@czp
Sep 23, 2019 03:30 PM
Depravity
Oct 1, 2015 04:49 PM
D_Rod
Sep 29, 2015 04:42 AM
