Step-By- Step Instructions on Replacing OEM Battery With An Optima Yellow Top...
Old Jun 6, 2007 | 02:45 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
By the way, what did you think about the rest of the thread. It's not like I'm out to set people's cars on fire.
The rest I liked! Good pictures and descriptions.
Old Jun 6, 2007 | 02:56 PM
Vestax's Avatar
Vestax
Nice how to.
Actually the latter is right, whether you're a car audio installer or a mechanic, it's always recommended to disconnect the negative terminal first. It's called electron flow (as oppose to conventional flow), and your entire chassis is one big conductive metal that completes the circuit.
Simply put, disconnect the positive first and the wrench hits the frame, you'll arc.
Disconnect the negative first, or the the positive 2nd, and hit the frame, nothing happens.
Old Jun 6, 2007 | 03:00 PM
VO...'s Avatar
VO...
Administrator
Thanks Paul.
Old Jun 6, 2007 | 03:01 PM
VO...'s Avatar
VO...
Administrator
Originally Posted by Vestax
Nice how to.
You guys win, 2 against one. I'll make the changes tomorrow. For now, I have to leave work.
Old Jun 6, 2007 | 03:16 PM
pony_killer's Avatar
pony_killer
Arada ninda apa
so with the yellow top, you can use the factory battery cover?
Old Jun 7, 2007 | 08:29 AM
VO...'s Avatar
VO...
Administrator
The only additional hardware you purchase is the battery and shims. That is all.
Old Jun 7, 2007 | 01:20 PM
VO...'s Avatar
VO...
Administrator
I would highly recommend following the procedure as outlined in the precautions section of the Nissan service manual and remove the ground (black (-)) terminal first. This presents a smaller exposure of high current discharge. When the wrench is connected to the negative terminal first the only thing you have to avoid contact with is the positive terminal which is normally protected with the red plastic boot cover. Do not short between the battery posts, this is a once in a lifetime mistake. If done positive first your wrench is connect to the positive terminal and you have to avoid contact with the entire car which is grounded to include the too easy to hit battery mounts, the fender, motor parts, and the top of the firewall.
I most highly recommend doing negative first. I've learned to respect the dangers that unprotected (fuses) high current sources present. Be careful out there.
I have edited my original instructions to reflect this procedure. Thank you for the correct info.
Old Jun 7, 2007 | 11:42 PM
gt3's Avatar
gt3
Awesome! Thanks for the detailed write-up.
Old Jun 8, 2007 | 06:41 AM
VO...'s Avatar
VO...
Administrator
NP
Old Jun 21, 2007 | 05:22 AM
jmark's Avatar
jmark
Nice writeup. What does the factory battery weigh?
Old Jun 25, 2007 | 08:01 AM
VO...'s Avatar
VO...
Administrator
I weighed it a couple nights ago for you. It weighd in @ exactly 37.3 lbs.
Old Jul 19, 2007 | 09:19 AM
VoKaL's Avatar
VoKaL
nice write up...but it looks more complicated in ur steps then installin a battery really is...lol...good work tho..
Old Jul 19, 2007 | 09:30 AM
TheProfessional's Avatar
TheProfessional
Great How to, thanks for this, I have been considering for a long time.
Old Jul 20, 2007 | 11:59 AM
VO...'s Avatar
VO...
Administrator
What can I say, I'm a perfectionist...
Old Jul 31, 2007 | 10:35 AM
LifeIsRisky's Avatar
LifeIsRisky
Mine is on order, should have it on Monday. Oh just for info it was $138. Gotta love having someone with a wholesale account at the local Interstate Battery.
Thanks for the info.
Old Jul 31, 2007 | 10:41 AM
VO...'s Avatar
VO...
Administrator
NP
Old Nov 9, 2007 | 05:48 PM
XIceDragonX's Avatar
XIceDragonX
Ahhh... 24.99 for my yellow top... part of my works great, get rid of any battery for used price that has sat for more than 6 months... I love when you find that little way to get back at your employer. I have yet to put it in, did the yellow top help any with voltage drop when your bass hits? Mine drops slightly currently, and I am hoping this yellow top fixes it.
Old Nov 12, 2007 | 12:23 PM
  #38
VO...'s Avatar
VO...
Administrator
Yes it did help, tremendously. It still fluctuates a bit, but nothing compared to the OEM battery.
Old Nov 15, 2007 | 08:14 AM
  #39
jamaicanj's Avatar
jamaicanj
Excellent write up.
Anyone know the difference between the boxed yelowtop and the unboxed yellow top battery??
Old Nov 15, 2007 | 08:17 AM
  #40
SuperBlack350z's Avatar
SuperBlack350z
Nice guide. I need to get another yellow top myself.
