time for a change in amps need help deciding
Old Jun 12, 2007 | 04:19 AM
Tackett's Avatar
Tackett
Default time for a change in amps need help deciding
ok, I had an old crossfire 400 watt 2 channel amplifer (by old I mean 10 years) pushing these CDT componets:
http://www.woofersetc.com/index.cfm?...roduct_ID=1101
The amps left channel has a short in it and its pissing me off reaching back and tapping the connection while driving...
So I was thinking of doing something different... Currently in addition to those front drivers, mounted using the wicked cas fiberglass door enclosures (which are freakin awsome.) The CDT tweets are mounted in the kick panels, and I have a couple of JL evolution tweets playing high fill 5-8khz in the stock position. and I am currently running this headunit
http://www.pioneerelectronics.com/pn...496601,00.html
and I have a pair of old Alpine Type R (total sucktitute) midbass drivers and crossovers lying around (these) the tweets are dead.
http://www.woofersetc.com/index.cfm?...roduct_ID=2457
What would be wrong with re-setting up everything as follows: Fill tweeters in stock position powered by new amp, Main tweeters in kick panels powered by same new amp, Front componet drivers powered by same new amp. Old alpine drivers placed in rear fill position run by headunit amplifier and utilizing the alpine crossover I have (or should I run them with the same CDT crossover that is running the fronts?) My sub is a jl12w6 powered by a phoenix gold xs2500 and that is not changing, still running beautifully.
anyone on to the list of amps that I found that I need you fine people to help me narrow them down.
first: four channel but bridgeable
http://www.woofersetc.com/index.cfm?...roduct_ID=2698
second: again four channels but bridgeable.
http://www.woofersetc.com/index.cfm?...roduct_ID=3807
I really would like to have this one, just because it would match my xs2500 and the power rating for bridging down to two channel is dead on 180rms.
http://www.woofersetc.com/index.cfm?...Product_ID=476
lastly, I dont think this amp has enough power to do what I want it to do.
http://www.woofersetc.com/index.cfm?...roduct_ID=4140
sorry for the long post and the rambling, thanks ahead of time all.
Old Jun 12, 2007 | 04:36 AM
350zspl's Avatar
350zspl
out of what you posted the CDT amp
i have been feeling these real bad
http://www.buycdt.com/SpeakerWorks/s..._ES62iUS07.htm
Old Jun 12, 2007 | 04:47 AM
Tackett's Avatar
Tackett
my next setup in any vehicle will be totally CDT. Im sold, sq is about 100 times better than anything else ive heard or tried. Do you think the CDT amp will have enough juice? Its only rated 100wx2 @ 4ohms and the drivers are rated at 180w rms.
Old Jun 12, 2007 | 05:13 AM
350zspl's Avatar
350zspl
i like the cdt better than the other brands you mentioned
if it is not pushing Rms than no but get a cdt sqa 2400
Old Jun 12, 2007 | 05:27 AM
Tackett's Avatar
Tackett
I really dont want to spend 550 beans on an amplifier, and that amp is way overkill for what i want to use it for. I wish CDT would make a larger selection of amplifiers rather than a whopping four options.
Old Jun 12, 2007 | 06:04 AM
350zspl's Avatar
350zspl
i run 600 watts to a set of components
RF-X162S Components
the pair of 6.5" and 1.1" are sharing the 600 watts
i kinda need it i have 5000 watts on my lows
that amp gained down would work , but the price is high
overkill is just about right for me
ZED ZA-DraconiaBB will have the power your looking for but is still $475
kyin
Oct 15, 2015 05:54 AM
nanotech
Oct 2, 2015 05:02 AM
Dymsi
Sep 29, 2015 11:32 AM
SharX59
Sep 27, 2015 09:23 AM
samansharif
Sep 25, 2015 12:31 PM
